Tah
Door pull cables
Demlotcrew
I used a cheapo dog lead off of eBay and just cut it to length.
You can just about see it in the top right of the photo.
Andrew
Andrew
Demlotcrew
I just used the handle, its very very light!
Or you can use a piece of string, you only need to pull on it.
ross_jsy
I've got to ask what is the point? As Demlot says the standard door pulls aren't exactly heavy and your solution is just going to look messy and shit, not to mention encroach in the cabin more than the standard handle.
rix313
- Contact:
Its not an issue with weight. The inside of the door has been skinned so there is no where to mount the handle and the door cards are fairly thin, not sure how much they'd flex and I don't want to cut a hole in the to find it twists about.ross_jsy wrote:I've got to ask what is the point? As Demlot says the standard door pulls aren't exactly heavy and your solution is just going to look messy and shit, not to mention encroach in the cabin more than the standard handle.
Not sure what I'm planning would look shit otherwise I wouldn't plan on doing it.
Rallyprep_UK
- formerly Driftnething
- Contact:
I used a seatbelt ! Will get a pic
http://www.ebay.co.uk/itm/porsche-911-r ... 0992181053
These?
Andrew did you make your cards yourself?
These?
Demlotcrew
Sadly not Phil!
The cards came with the doors and are custom only fit made from Aramid for extra safety.
I recently bought a half decent vacuum pump and hope to be making lots of carbon parts in the near future.
First up will be some engine bay parts moving on to a sunroof panel.
Rallyprep_UK
- Contact:
A spare pair of E30 belt's recycled !
