induction kit heatshield
Osamam3
to the guys that run s50 engines is there any chance that any of you have fitted heat shields around the filter ? i'm hoping i can see so,e pics to get an idea if this is do able. thanks
Osamam3
why ? i'm trying to check if there is a way to stop the car from breathing hot air from the engine.
zd3bx
I thought original air boxes with K&N panel filters were always a better option that induction kits...
Osamam3
mine has a cone i think i might best get the original one as it will be best for the engine.
jmc330i
Not such an easy option on an S50 converted E30 especially if the car has ABS, as the pump gets in the way of the S50 airbox. It is possible to move the ABS pump, but its a lot of work.zd3bx wrote:I thought original air boxes with K&N panel filters were always a better option that induction kits...
Here's my heatshield attempt before I finished it...
The filter was large and sat pretty much on top of the ABS pump. The heatshield curved around the filter, right down to the top of the chassis rail and slotted into a couple of the handy holes. The top of the heatshield was held in place by the retaining clips for the plastic headlight trim (that was removed so the filter got its fresh air).
I did eventually enclose the rear of the filter, but don't have any pics of it finished.
It was just a cheap and cheerful heatshield made from some bent/shaped sheet of stainless steel, but it did the job and definitely made a decent induction noise
I may have a sound clip on my old hard drive if I can find it
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
GDBN
K&N make something called a powerblanket.
That would do the trick.
I deserve 6 of the best ...
