How to set rear tires to 0 camber ??
KiNaKa
Post Mon Jan 09, 2006 5:17 pm
Hie dude,
ANybody know what can i do to set zero camber to my e30 rear tires ??
What part can i use ??
Thank in advance...
Regards,
Daniel
Demlotcrew
Post Mon Jan 09, 2006 5:18 pm
Why do you want 0 camber?
Andrew
KiNaKa
Post Mon Jan 09, 2006 5:20 pm
Demlotcrew wrote:Why do you want 0 camber?
Andrew
In my humble opinion, 0 camber leads me to more traction control when doing power slide...
do you agree ???
kam-325i
Post Mon Jan 09, 2006 5:27 pm
Would you not want a slight negitive camber for power sliding ?
KiNaKa
Post Mon Jan 09, 2006 5:39 pm
first of all i want to have an even tire wear...
second, if negative camber, will my left wheel lose abit of traction when i sliding to the right ???
Demlotcrew
Post Mon Jan 09, 2006 5:48 pm
0deg camber will not give you even tire wear, best of to leave it as is and get over sized wheels and strech a tire on those, this will make the car better to slide as the tire wall wont flex and you will get good even wear.
If you have 0 deg camber the outer edge of the tire will wear very quickly.
Andrew
KiNaKa
Post Mon Jan 09, 2006 6:04 pm
yup i agree on you...
but in fact in malaysia is very hard to get oversized wheel for e30...
will the oversized wheel on e30 looks more to zero degree camber ???
becoz some of the e30 i saw their camber are too negative for rear wheel, and the wheel look inside the fender..
some i saw the rear wheel are in line with the rear fender...
whats diffrent betwen this ??
thanks...
astondg
Post Tue Jan 10, 2006 12:59 am
Lowering the car will increase negative camber, were both the cars the same height?
I think I understand what you mean about the left wheel if you are sliding to the right but negative camber does increase the grip. One thing to consider is that when cornering or sliding the weight is shifted to the outside tye and I think it is most important for grip and it's grip will benefit from negative camber. The inside tyre might loose a little bit but if you have an LSD the inside wheel won't spin until the outside one has lost grip as well. Some cars even lift the inside wheel off the ground into corners and it doesn't effect the overall grip too much.
If you still want to change it you can get adjustable trailing arm bushes but I don't know if they can go to 0 degrees of camber, it depends how much you have now.
Aston
BMW E30 323i with some stuff
1:05.17 @ Queensland Raceway Sprint track
1:10.09 @ Queensland Raceway Clubman track
1:21.67 @ Morgan Park Raceway
KiNaKa
Post Tue Jan 10, 2006 1:25 am
astondg,
oh all right.. i get what do you mean.... thanks for your info...
btw does anyone know what is the offset for the rims using on the e30 in my signature ???
anyone know where can get the info of this car...
his rear wheel camber seems to be zero...
Daniel
kam-325i
Post Tue Jan 10, 2006 10:21 am
That E30 in your sig has Neg camber on the rear.
Demlotcrew
Post Tue Jan 10, 2006 10:58 am
IF you really want to do it, then you can get bushes from BMW that will bring the camber closer to 0 when the car is lowered, but you really dont want 0, plus these bushes wont get you to 0.
Andrew
