Pistons not from original engine.
gooner1
Out humping Reindeer
Post Wed Sep 25, 2013 11:37 am
Morning all.
Now I know that when rebuilding an engine, that the pistons
must be situated in their original bores, but what is the procedure
when using pistons from another block.
Same type of pistons and engine btw.
TIA, Rob.
Post Wed Sep 25, 2013 11:52 am
The rings and shells are the important bits.
Hone the bores and with new rings it'll be fine. The rod that matched the new piston is better kept as the small end matches. New big end shells will suffice.
It's the rings that need to go back it the same bore not necessarily the piston.
gooner1
Post Wed Sep 25, 2013 12:00 pm
Cheers for that Trev, Bores already honed and have all new rings but for some reason
I was convinced that pistons had to be placed in original location. :thumb:
Post Wed Sep 25, 2013 12:21 pm
I suppose there could be a balance issue on some engines. Ie if the bottom ends been balanced then yes its essential that the order is kept. But for a run of the mill donk I can't see an issue.
HairyScreech
Post Wed Sep 25, 2013 1:12 pm
Afaik there isn't actually any reason that dosen't have 15 solid counter arguments, if you have mixed the pistons up just get a scale and pair them up to prevent a rocking motion.
gooner1
Post Wed Sep 25, 2013 3:11 pm
This is for my 2.8 build.
Unfortunately I have cleaned the pistons from the original block, with scotchbrite, that much that
i'm now dubious about using them. :o:
Post Wed Sep 25, 2013 8:09 pm
Dont worry about scotchbrite, just make sure you get the ring grooves scrupulously clean, I find acid works a treat :D
gooner1
Post Thu Sep 26, 2013 5:01 pm
If there is ever a "next time" Dan, acid will be the route I take.
