Are the speakers 5.25''? About to buy a set of components but want to make sure they fit..
cheers
Size of speakers in a 316?
toby
Yes, front speakers standard fit size.
Junglistjed
Will i need adapters? not sure how deep the speaker spot is
toby
It should just fit in as long as the magnets aren't too deep. You could measure the depth and then check the technical specs of the speakers you're after. It's tricky to use spacers or even grills as they foul the glovebox/ bonnet release lever.
