Hi I was wondering if anyone could help me. I have an e30 325i mtech 2. Yesterday when I turned the car off and removed the key. I then noticed the rev needle moved from 0 to just under a 1000 rpm although there was no ignition or power to the car? I also noticed that my fuel consumption sits at 0 when I'm stationary is this correct as its smells very rich and every now and again cuts out? Would be great full of any help or feedback.
Regards Ryan
Strange goings on!
Sounds like you're over fuelling (for the rich small and cutting out), the fuel consumption is correct when stationary.
Over fuelling can be attributed to the blue temp sensor so it's worth testing that before you start fiddling with other bits.
What RPM does the car idle at by the way?
1988 325i Cabriolet - Gone.
When the car is stationary, it will be doing 0mpg.Ryane30 wrote:I also noticed that my fuel consumption sits at 0 when I'm stationary is this correct
Blue temp sensor - http://www.e30zone.net/e30zonewiki/inde ... emp_Sensor
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Strange instrument fluctuations are usually a sign of failing SI board batteries - do your SI lights work OK?
They often fail with the Inspection light on! Try resetting them, and see if they work OK.
http://www.e30zone.net/e30zonewiki/inde ... ion_Lights
Try cleaning the contacts with a fine brass wire brush or similar, perhaps used in conjunction with electrical contact cleaner spray.
