When I stripped the 325 to build my Marlin Sportster I found one of the rear springs was broken - in fact about half a coil was missing from the top. My 318is now seems to have developed a list to one side - I suspect the same problem.
Are broken rear springs common on the E30?
Robin
Broken rear spring - is it a common problem
martinclan
It's an E30 Jim but not as we know it...
Ant
- Retired Team Member
tis indeed a common failing Robin, one that affects all bmws including the newer models
Email FTW
Simon
Deffo, I've had 2 myself!
JazzMan
I had a broken spring on the E30 Touring I broke for my Sportster.
Also my E46 Coupe has had two broken rear springs as well! Seems to be a common BMW thing. I've replaced the OE springs in my Coupe with Eibach ones. We shall see how long they last.
