Wed Aug 07, 2013 11:52 am
Quite neat. Was that done with a hammer and dolly, or a rolling wheel?
driftwood
Wed Aug 07, 2013 12:25 pm
Used a bead roller, shrinker/stretcher and hammer and dolly. Am slowly building up my collection of metalwork tools.
driftwood
Wed Aug 07, 2013 7:05 pm
Felt enthusiastic so also made this, another patch for inner rear wheel arch. Not perfect but doesn't have to be. Probably won't do any more for weeks.
Wed Aug 07, 2013 10:43 pm
Not bad. Nice sharp creases there. 8)
Wed Aug 07, 2013 11:46 pm
Had some more done to it to P1ss of "Boycie"
Loved it. :D :wink:
oomz1975
Thu Aug 08, 2013 7:45 pm
Replaced the throttle body with a spare,
Cleaned out the ICV,
Fixed a wobbly headlight,
Took it for a blast up the A40...
assassin
Thu Aug 08, 2013 8:22 pm
Reversed mine into a wall. :x
FinalD
Thu Aug 08, 2013 10:45 pm
Went for a drive yesterday and heard a rotational scraping noise when the car was warmed up after a few miles, it was speed based so knew it would be a wheel or something around one.
Worked out it was the OSR wheel so pulled the wheel so tonight I pulled the wheel and disc off to be greeted with this:
and
Now these pins and springs were all new back in Feb of this year, I can only assume that the backplate is knackered which has caused the pin to get thrown around the inside of the brakes (luckily it's only the handbrake).
I'll pick up a new pin and spring from my local BMW at the weekend and see if I can fix it, really rather annoying though, makes the handbrake a bit dodgy and also means driving it shaves off loads of friction material from the shoe that is loose.
Thu Aug 08, 2013 10:56 pm
That backplate's definitely seen better days! However, I've heard of folk doing away with the pins that pull through enlarged holes, and instead use bolts and the springs/washers to secure the shoes.
mikelat
Fri Aug 09, 2013 1:23 am
Update to my oil pan gasket replacement. Got the pan off using the Bentley method with lots of fiddling but wouldn't go back without messing up the pan mating surface so jacked up the engine on the A/C bracket. Couldn't get the gasket to stay on either the engine or the pan using sealer so cleaned both and then used thread to tie it to about 10 pan bolt holes and all went fine. Pissy job.
Mike
1990 325i Coupe Gletscherblau_Metallic
tomislav
Fri Aug 09, 2013 1:13 pm
Crashed it at the Nurburgring 3/8/13, bye bye to another e30 i'm afraid
Fri Aug 09, 2013 1:35 pm
Photos or it didn't happen! :wink:
tomislav
Fri Aug 09, 2013 1:36 pm
Gimme a few days and i'll get photo's, inside and outside video's too
Fri Aug 09, 2013 1:37 pm
Hope you're OK, that's the main thing.
tomislav
Fri Aug 09, 2013 1:40 pm
Nah, black 325i 2dr, just had it mopped, bits painted, wheels refurbed, loads of work done and now the left side of the boot is a bout 6 inches higher and shorter than the other side lol.
No casualties tho, scott (the passenger) and I both walked away, even managed to drive the car home
FinalD
Fri Aug 09, 2013 1:41 pm
Pics please... :P
tomislav
Fri Aug 09, 2013 1:42 pm
tomislav wrote:Gimme a few days and i'll get photo's, inside and outside video's too
Fri Aug 09, 2013 1:45 pm
No way you can straighten it out then, or is reshelling the only option?
tomislav
Fri Aug 09, 2013 1:47 pm
Needs a reshell, theres a creace in the roof, how the rear window didnt smash i dont know, both chassis leg ends at the back are properly crumpled. Its not worth the agro to even try
Fri Aug 09, 2013 2:18 pm
Sure. Oh well, best of luck finding a replacement...
FinalD
Fri Aug 09, 2013 6:07 pm
I was tired, didn't spot that.
Fair play for your being a man about it though, did you have a hefty bill for armco too? :(
hennabm
Fri Aug 09, 2013 8:34 pm
Filled the tank and then cleaned the car inside and out ready for showing on Sunday winkeye
I did notice that it tended to stand out amongst all the drab looking moderns at the petrol station. :wink:
'82 323i henna
'10 116d Sport Red - MkI
'11 X3 3.0d SE
'89 240 DL Estate
darkchild
Fri Aug 09, 2013 9:12 pm
darkchild wrote:Bought it a new tax disc. And a new engine. Hopefully it'll be back on the road next week. :D
And fixed!
Got a very nice low mileage engine delivered from BBB. It already had a new water pump, plugs etc which was an unexpected bonus. Only drama was a few snapped exhaust manifold studs but they're all fixed now.
Picked it up today and everything is running sweet. A nice smooth engine which seems to have just that little bit more oomph than the original lump. Even managed to achieve 34mpg according to a no doubt slightly optimistic OBC on my 30 mile journey home! Really glad to have the old girl fixed and back in service. Admittedly its money I'll never see again but I'm happy its back on the road. :D
Fri Aug 09, 2013 9:40 pm
f00k all....it hates me !
gooseygander110
Fri Aug 09, 2013 10:05 pm
nothing ....and proud !! lol
gooseygander110
Fri Aug 09, 2013 10:06 pm
oomz1975
Fri Aug 09, 2013 11:11 pm
hennabm wrote:Filled the tank and then cleaned the car inside and out ready for showing on Sunday winkeye
Had one of those petrol station moments this evening.
Got plenty of 'runnings' to get on with the next few days.
darkchild
Sat Aug 10, 2013 2:30 pm
Took it on a trip to the Norwich Motor Show. Nothing too exciting spotted - usual collection of Triumphs & MGs, a few vintage Fords, an Allegro Post Office Van and a C Plate Granada! Thats the classic motoring scene in Norfolk!
Cooper BMW had a small selection there. A very nice white M6 coupe, a 120d, a selection of Minis and a boring as f*ck F30 316i with awful fabric seats... utterly bland. Mind you, infinitely preferable to anything on the Peugeot stand - ugly 208s and a hideous and pointless flid-chariot called a 107. :eek:
dazleeds
old skool raver
old skool raver
Sat Aug 10, 2013 3:06 pm
charged he battery put it back on to discover my alarm had lost the plot so went wire hunting and disabled the bugger :)
searched out some rust then came back indoors lol
hmmm weld up or reshell that is the question :roll:
www.oldskoolfantasy.co.uk
tomislav
Sat Aug 10, 2013 4:26 pm
Hit the only piece of concrete barrier on the whole circuit, lucky, kind of.
All told cost me 490euros to get it all sorted which really is a lucky escape.
Lesson learnt
tomislav
Sat Aug 10, 2013 4:28 pm
Oh, and to keep this on topic, today i have started stripping EVERYTHING off the car that isn't bent, which is annoying cos i only had the front and rear subframes off 2-3 months back for a refurb.
e30den
Sat Aug 10, 2013 5:49 pm
Layed another coat of wax on the e30 before the standard early morning sunday drive on some of kents finest roads.
shedrool83
Sat Aug 10, 2013 7:05 pm
More for the e30 rather than doing something to it.
Spent the last week painting the garage floor.
After the first day i wished i had never started it but now it's done i'm glad i did as it was needing it and was badly needing a tidy.
toby
Sat Aug 10, 2013 7:42 pm
That is a sweet workshop man.
