Mondeo ARB drop links
pipework
Post Wed Aug 07, 2013 12:41 pm
Hello, just wondering if anyone has fitted mondeo estate
drop links to the front ARB. Is it worth doing??
Rtaylor2208
Post Wed Aug 07, 2013 12:44 pm
Yes and yes. There was a thread recently in the tech help section that BrianMoore linked the parts with on CarParts4Less.co.uk.
Grrrmachine
E30 Zone Wiki / Team Member
Post Wed Aug 07, 2013 12:52 pm
pipework
Post Wed Aug 07, 2013 1:18 pm
Cool. Ill chuck a pair of them on then. Thanks guys!
Meatballs82
Post Wed Aug 07, 2013 1:21 pm
Partnumber for the Lemforders at ECP is 632590095 - in stock :D
ravstar13
Post Wed Aug 07, 2013 1:28 pm
Is this for all models?? estate/coupe etc and 316i to 325i??
**BANNED**
Post Wed Aug 07, 2013 2:59 pm
ravstar13 wrote:Is this for all models?? estate/coupe etc and 316i to 325i??
2 and 4 door saloon,cabbie and touring in all engine sizes :D
craigieeb
Post Wed Aug 07, 2013 4:32 pm
Meatballs82 wrote:Partnumber for the Lemforders at ECP is 632590095 - in stock :D
Looks like that part number works on the cheaper carparts4less website toooo :P
Meatballs82
Post Wed Aug 07, 2013 4:37 pm
There goes my steak dinner tonight! :(
winkeye
stew72
Post Thu Aug 08, 2013 7:01 am
I replaced one of mine with a standard item. Considered doing this and replacing both, but technically this would be a modification therefore could cause insurance grief. Unlikely, but it could.
lhd220turbo
Post Thu Aug 08, 2013 9:59 pm
stew72 wrote:I replaced one of mine with a standard item. Considered doing this and replacing both, but technically this would be a modification therefore could cause insurance grief. Unlikely, but it could.
no offence but have you been through every single component on your car to ensure its correct to exactly how it left the BMW factory?
HairyScreech
Post Thu Aug 08, 2013 10:06 pm
He does have a point unfortunately, However shit it may be it could still be an issue. :x
Post Thu Aug 08, 2013 10:21 pm
My Mondeo estate is wearing part worn E30 drop links :D
jmc330i
Post Thu Aug 08, 2013 10:46 pm
HairyScreech wrote:He does have a point unfortunately, However shit it may be it could still be an issue. :x
It could be an issue if the insurance assessor knows the difference. If for example a rose jointed drop link was used (or other obvious aftermarket part), I'm sure it would be picked up, but a standard looking car part....?
James
'91 325i Sport
'93 318i touring 16v
stew72
Post Sat Aug 10, 2013 7:37 am
If the images on ecp's website are correct then an assessor would be able to tell if they knew what they were looking for, which with the help of the internet wouldn't be too difficult.
Again if the images are correct it looks like you need to drill the control arm and probably remove the old bracket. Can anyone confirm?
PG325
Post Sat Aug 10, 2013 8:08 am
You don't need to drill the arm, just remove the bracket and bolt in.
Post Sat Aug 10, 2013 9:09 am
stew72 wrote: If the images on ecp's website are correct then an assessor would be able to tell if they knew what they were looking for, which with the help of the internet wouldn't be too difficult.
No mods. required at all. Just a straightforward replacement.
The chances of an insurance assessor noticing, or caring in the unlikely event that he did, are negligible.
jmc330i
Post Sat Aug 10, 2013 12:57 pm
That's point I was trying make.
If you'd fitted rose joint drop links that are obviously not standard, then the assessor will probably look closer (and at the rest of the car also), but with the mondeo parts not looking like an aftermarket part, I'm sure it wouldn't even be noticed.
James
'91 325i Sport
stew72
Post Sat Aug 10, 2013 8:02 pm
I agree with noticing, but whether he cares or not would depend on whos side he's on.
**BANNED**
Post Sat Aug 10, 2013 8:23 pm
Perhaps you could care to explain just how an ARB link of a different design would affect an inspector's POV?
stew72
Post Sat Aug 10, 2013 8:42 pm
daimlerman wrote:
stew72 wrote:
Brianmoooore wrote: No mods. required at all. Just a straightforward replacement.
It could be interpreted as a modification. I agree unlikely, but its possible.
Andyboy
Alpina Colada
Post Sun Aug 11, 2013 11:00 am
What about Titanium, Aspen and Ghia X?
