Mondeo ARB drop links
pipework
Hello, just wondering if anyone has fitted mondeo estate
drop links to the front ARB. Is it worth doing??
Rtaylor2208
Yes and yes. There was a thread recently in the tech help section that BrianMoore linked the parts with on CarParts4Less.co.uk.
Grrrmachine
- E30 Zone Wiki / Team Member
pipework
Cool. Ill chuck a pair of them on then. Thanks guys!
Meatballs82
Partnumber for the Lemforders at ECP is 632590095 - in stock
ravstar13
Is this for all models?? estate/coupe etc and 316i to 325i??
- **BANNED**
2 and 4 door saloon,cabbie and touring in all engine sizesravstar13 wrote:Is this for all models?? estate/coupe etc and 316i to 325i??
craigieeb
Looks like that part number works on the cheaper carparts4less website tooooMeatballs82 wrote:Partnumber for the Lemforders at ECP is 632590095 - in stock
M50 Turbo!!!
I shall say no more
Meatballs82
There goes my steak dinner tonight!craigieeb wrote:Looks like that part number works on the cheaper carparts4less website tooooMeatballs82 wrote:Partnumber for the Lemforders at ECP is 632590095 - in stock
stew72
I replaced one of mine with a standard item. Considered doing this and replacing both, but technically this would be a modification therefore could cause insurance grief. Unlikely, but it could.
lhd220turbo
no offence but have you been through every single component on your car to ensure its correct to exactly how it left the BMW factory?stew72 wrote:I replaced one of mine with a standard item. Considered doing this and replacing both, but technically this would be a modification therefore could cause insurance grief. Unlikely, but it could.
HairyScreech
He does have a point unfortunately, However shit it may be it could still be an issue.
My Mondeo estate is wearing part worn E30 drop links
jmc330i
It could be an issue if the insurance assessor knows the difference. If for example a rose jointed drop link was used (or other obvious aftermarket part), I'm sure it would be picked up, but a standard looking car part....?HairyScreech wrote:He does have a point unfortunately, However shit it may be it could still be an issue.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
stew72
If the images on ecp's website are correct then an assessor would be able to tell if they knew what they were looking for, which with the help of the internet wouldn't be too difficult.jmc330i wrote:stew72 wrote:I replaced one of mine with a standard item. Considered doing this and replacing both, but technically this would be a modification therefore could cause insurance grief. Unlikely, but it could.It could be an issue if the insurance assessor knows the difference. If for example a rose jointed drop link was used (or other obvious aftermarket part), I'm sure it would be picked up, but a standard looking car part....?HairyScreech wrote:He does have a point unfortunately, However shit it may be it could still be an issue.
Again if the images are correct it looks like you need to drill the control arm and probably remove the old bracket. Can anyone confirm?
PG325
You don't need to drill the arm, just remove the bracket and bolt in.stew72 wrote:If the images on ecp's website are correct then an assessor would be able to tell if they knew what they were looking for, which with the help of the internet wouldn't be too difficult.jmc330i wrote:stew72 wrote:I replaced one of mine with a standard item. Considered doing this and replacing both, but technically this would be a modification therefore could cause insurance grief. Unlikely, but it could.It could be an issue if the insurance assessor knows the difference. If for example a rose jointed drop link was used (or other obvious aftermarket part), I'm sure it would be picked up, but a standard looking car part....?HairyScreech wrote:He does have a point unfortunately, However shit it may be it could still be an issue.
No mods. required at all. Just a straightforward replacement.stew72 wrote: If the images on ecp's website are correct then an assessor would be able to tell if they knew what they were looking for, which with the help of the internet wouldn't be too difficult.
The chances of an insurance assessor noticing, or caring in the unlikely event that he did, are negligible.
jmc330i
That's point I was trying make.Brianmoooore wrote:No mods. required at all. Just a straightforward replacement.stew72 wrote: If the images on ecp's website are correct then an assessor would be able to tell if they knew what they were looking for, which with the help of the internet wouldn't be too difficult.
If you'd fitted rose joint drop links that are obviously not standard, then the assessor will probably look closer (and at the rest of the car also), but with the mondeo parts not looking like an aftermarket part, I'm sure it wouldn't even be noticed.
James
'91 325i Sport
'91 325i Sport
stew72
I agree with noticing, but whether he cares or not would depend on whos side he's on.Brianmoooore wrote:No mods. required at all. Just a straightforward replacement.stew72 wrote: If the images on ecp's website are correct then an assessor would be able to tell if they knew what they were looking for, which with the help of the internet wouldn't be too difficult.
- **BANNED**
Perhaps you could care to explain just how an ARB link of a different design would affect an inspector's POV?stew72 wrote:I agree with noticing, but whether he cares or not would depend on whos side he's on.Brianmoooore wrote:No mods. required at all. Just a straightforward replacement.stew72 wrote: If the images on ecp's website are correct then an assessor would be able to tell if they knew what they were looking for, which with the help of the internet wouldn't be too difficult.
stew72
daimlerman wrote:It could be interpreted as a modification. I agree unlikely, but its possible.stew72 wrote:I agree with noticing, but whether he cares or not would depend on whos side he's on.Brianmoooore wrote: No mods. required at all. Just a straightforward replacement.
Andyboy
- Alpina Colada
What about Titanium, Aspen and Ghia X?daimlerman wrote:2 and 4 door saloon,cabbie and touring in all engine sizesravstar13 wrote:Is this for all models?? estate/coupe etc and 316i to 325i??
