1986 316 M10 carb
Automaton
Wed Jun 26, 2013 4:01 pm
After years of looking around, found an E30 that i could buy and afford.
Knowing well that it would cost me as much in parts, shipping and customs as the already high cost of the car.
It pains to see so many 'perfectly reasonable' condition E30 being broken, but i guess that is the way it is.
Putting up a few pictures. They are mostly about all the things that have gone wrong (almost everything :)) with the car.
Bought it on 2nd April 2013 and the last few months have been spent poring over various rebuilds, asking questions, and collating as much info as I can cram in a short span of time.
After about 15 days of careful driving, the last 2 months it is on stands awaiting parts.
As I found it, in a dump, literally. Seeing its condition, not surprising.
A few other pics:
Drove it home after closing the deal and getting it registered to my name:
And then to my garage to get it on the ramp for an inspection.
Yes, I checked it after I bought it.
Wrote to BMW India and they referred the query to BMW Germany for manufacturer info, as I wanted to know what all it had left the factory with so that I can put it all back in due course of time.
This is the sheet they emailed:
BLB 0115
Vehicle information
VIN long WBAAC52080176XXXX
Type code AC52
Type 316 (EUR)
Dev. series E30 ()
Line 3
Body type LIM
Steering RL
Door count 4
Engine M10
Cubical capacity 1.80
Power 90 PS
Transmision HECK
Gearbox MECH
Colour SCHWARZ (086)
Upholstery ANTHRAZIT (0251)
Prod. Date 1986-11-06
Order options
No. Description
215 POWER STEERING, DEPENDING ON ENGINE SPEED
300 ZENTRALVERRIEGELUNG ELEKTRISCH (Electric Central Locking)
311 ELEKTRISCHER BEIFAHRERSPIEGEL (Electric Passenger Rear View Mirror)
350 WAERMESCHUTZGLAS GRUEN, RUNDUM (All-round Green Insulation Glass)
401 SLIDING/VENT ROOF, ELECTRIC
411 WINDOW LIFTS, ELECTRIC
530 AIR CONDITIONING
650 BMW Bavaria C
682 RADIO ANTENNA AUTOMATIC
690 CASSETTE HOLDER
823 HOT CLIMATE VERSION
850 ADD FUEL TANK FILLING FOR EXPORT
Took it to Navnit Motors, and it broke down. Push start wouldn't help. We suspect it may be the fuel pump. So it was towed back to the garage, and clicked a few pictures, as I was leaving for Thailand for a short holiday and had convinced the missus to agree on a destination that could also double up as a parts source. She agreed after much misgiving as going from the summer of Mumbai to sweltering Thailand didn't exactly constitute an escape.
Up it went on stands
Hopes up of finding the parts
I knew that language would be a big issue in Bangkok, as the parts shop owners are not conversant with any language other than Thai. Still managed to find 2-3 who spoke a smattering and could help me.
The pictures i had clicked detailed what I wanted:
The plastic surround:
Square eyelet cover: Or whatever it is called.
Flaps: but didn't get any. The right bottom is the mother-load of rust. Fist sized or more.
The under steering cover:
Had a tough time carrying it on the way back along with a used glove box and latch.
What is the aluminum box with the pink mark?
The handle and the electric mirror switch
Original door latches instead of the Hyundai Santro stuff:
Rubber surround for the window, above the door card.
Cracked old gear knob:
As you can see the list is endless.
Front ashtray has a burn mark. Would require advise on how I can repair/restore this.
The rear is broken
These don't work. And the belt has gone slack. Any way to repair the belts?
The Carb as is. Suspected to be a Suzuki carburetor. Discovered that all the E30 Carb car owners in Thailand are running old Honda Accord carbs as they are the 'best'. Or most of them have dumped the M10 for a Nissan 2.5L engine.
And while on it, this is the Suzuki Jimny 410 Air box:
The fuse box cover has warped. Heat?
These don't work. Why am I even writing this?
Thanks to Instagram, these old yellowed frames are in fashion.
The rear view is the same:
The temperature gauge doesn't work, so got a new one. Along with a temperature sensor.
The seller has tampered with the odometer and has clocked it back by 20-30000 miles.
The central locking doesn't work or the fuse is gone, we will check that. Soon.
Electric Antenna is jammed
Radio doesn't work or maybe again a question with the electrics/fuse.
The AC switch is again from either Hyundai or Suzuki. Not sure. Don't care.
The leather surround for the gear knob is cracked/torn. Have got that and a new knob, and the bushing and rubber gaiter.
Took it to the AC shop. 26 years of dirt.
Rusted headlight brackets. And no leaks in the lines.
Discovered that the AC is now 'direct'
And a Mercedes 190E part powers it
Other engine bay close ups:
Notice the battery held in place by the corrugated cardboard piece.
The AC guys hard at work, trying to decode the mysteries:
The expansion valve is so rusted that he said if I touch it, it will break off.
And when I wrote to Pelican parts, the advice is quite detailed and confusing.
Can anyone help me with parts for a AC system changed to R134-A. The compressor is Ok. The expansion valve, the dryer/receiver and the switch need to be changed.
Three shipments have arrived.
Smaller stuff is coming via our forum members HJG-E30 and Hennared323i.
Ebay.co.uk is proving to be a boon. And those things are trickling in as fast as Royal Mail can handle.
Maneesh
1986 E30 M10 316 Manual Schwarz Chromie
1982 E28 M20 520i Henna Rot - Project
1988 E32 M70 750iL Schwarz - MASSIVE Project
1991 W201 190e Automatic Schwarz - Sold
1991 W201 190e Automatic Silver AMG Tribute - Sold
1993 E36 M40 316i Manual Brillantrot (RIP: rotting in peace)
Join other Carb Fanatics: E30 316 Carb - The Faithfuls https://www.facebook.com/groups/444263742439145/
Wed Jun 26, 2013 4:31 pm
Not bad. That looks proper ghetto, that place you bought it from - parked up next to the local drug dealer's blacked-out Benz! :eek:
Automaton
Wed Jun 26, 2013 5:19 pm
Yes it was. But was glad I passed that way on a whim.
Maneesh
Wed Jun 26, 2013 5:37 pm
The box with the label on is the ECU (Engine Control Unit). Normally used to control the carb on the M10 engine.
Automaton
Wed Jun 26, 2013 5:54 pm
Oh crap.
Thought these came without sensors and ECUs.
The plague that killed my E36
Maneesh
Wed Jun 26, 2013 5:58 pm
Well, I'm no expert on the M10 models; it may well just control the ignition side of things.
I gather the original Pierburg carb was ECU controlled.
Likelihood is, if someone's fitted a Suzuki carb, then it will have no effect on the carb operation.
AdamBeevers
Wed Jun 26, 2013 7:16 pm
Woah, mega ghetto stuff going on there, using all sorts of parts 'just to make it work'!
Certainly an interesting read aha.
Wed Jun 26, 2013 8:05 pm
Keep on going :cool:
Duke137
Wed Jun 26, 2013 9:12 pm
Wow, great thread. I admire the way that cars are kept on the road in Asia/Africa when parts are not available they improvise and make their own parts :mad: I know it's ghetto but it's pretty cool at the same time!
OP, I sent you a PM 8)
kieran325
Wed Jun 26, 2013 9:17 pm
Well done and 10/10 for cracking on with it 8)
suedenim
Thu Jun 27, 2013 4:03 am
Interesting read. Are those niggly bits of trim etc hard to get hold of over there?
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
Automaton
Thu Jun 27, 2013 7:28 am
Speedtouch: Will need info on connecting this ECU to the new Weber carb that i have got. Will appreciate advice on this a little later.
Adambeevers: 'Make it work any how' may be ok for cheaper cars, actually for no car, but can't understand it for this one as it is easier to import parts now. Though maybe the ex-owner(s) may not have appreciated the 316 and couldn't justify the additional expense.
Rav335uk and Duke137: Have replied to PMs. Will keep all posted on how it's going.
Kieran325: Thanks, i need all the courage and encouragement. It's my first project and sometimes it feels like swimming in cold, deep water.
Suededenim: My mechanic was aghast that i was ordering parts from EU. He was confident that the 3-4 old parts shops in central Mumbai, (these guys sell parts for all imported cars for decades.) will have them all, or can get it cheap.
We went there, and all they could dig out from the store room were the Front 45mm Monroe shocks and rear wheel bearings, which I had got from Bangkok already. Nothing else.
For me the irritant is the small stuff, hate to put together things without the correct pins, locks, screws and clamps. The beginning of it all looking a bit off is when non-oem stuff is used to put it together.
Maneesh
Automaton
Thu Jun 27, 2013 8:14 am
The things in the mail:
UJ from Hennared323i
Sunroof motor parts from HJG-E30
Brake Cylinder kit from Alumaseal (ebay.co.uk seller)
Brake spring set, Bonnet gas shock and Lower arm bushing from Schmiedmann, DK
All rubber window liners, inner and outer door sills, M10 rubber air hose, bonnet gas shock clamps hopefully dispatched soon from BMWspareshop (ebay.co.uk seller)
Maneesh
Thu Jun 27, 2013 9:54 am
Automaton
Thu Jun 27, 2013 10:33 am
Read it twice. Hopefully it will make sense to my mechanic, when I read out the contents to him.
And that means, I will keep my new Weber carb aside till I get it up and running again and then experiment with things that ain't broke.
Thanks.
Maneesh
verde
Thu Jun 27, 2013 10:46 am
Forgive my arrogance, but India sounds an extremely difficult place to live if your into actually looking after/maintaining and keeping a vehicle in good condition.
Excited to see this progress however.
Raise hell praise Dale.
Automaton
Thu Jun 27, 2013 11:15 am
verde wrote:Forgive my arrogance, but India sounds an extremely difficult place to live if your into actually looking after/maintaining and keeping a vehicle in good condition.
Only pre-94 BMWs. Only people bored with life or in Advertising would take up such a foolish project.
The only progress I've made is that I've found names and a few emails of the 12 E30 owners in India. Don't know how it's going to help :)
Maneesh
Automaton
Tue Jul 16, 2013 8:12 am
Got some crucial parts from a bunch of places.
Hennared323i sent the all important UJ
HJG-E30 for the Sunroof motor
Gemma T on Ebay.co.uk sent the replacement cassette holder and the rear ashtray.
AlumaSeal on ebay.co.uk couriered the rear brake cylinder kit
K&N Bolt on kit from Amazon.com, since I don't have the round, black original filter cover.
Schmiedmann.com for a ton of parts in three batches:
1. The brake springs, trailing arm bushing, and bonnet shock.
2. Stabilizer Link Rear
Stabilizer bush front
Sunroof Gasket
Clamp for covering behind Headlights or Dashboard
Clamp for Door Lining Lower Part
Clamp for Grille left
Clamp for door lining Upper Part
Clamp with lock pin (expanding rivet) for trunk lining
Chrome moulding front door left side
Chrome moulding front door right side
Number plate lights
Foglight frame plastic
Gear lever cover black leather
Plastic screws for covering under steering wheel
Seat belt stop lower part
Actuator Front doors locks
Actuator Rear door locks
Actuator Trunklid lock
Actuator Fill in Lid lock
Relay central locking system
Schmiedmann First Aid Kid Plus Warning Triangle
BMW USB Charger
BMW original Electric Antenna Black retrofit kit
UUC Motorwerks Magnetic Oil Drain Plug
Fuel Filter
Camshaft Chain
Camshaft Chain Slide rail
Camshaft Chain Slide rail Tensioner
Camshaft Chain tensioner
Distributor Cap
Rotor for Distributor cap
Temperature Sensor Water
Oil pressure switch
Fuel Pump
Thermostat 80 CEL with housing
Gearbox Rubber mounting for 5 speed models
Engine Mounting M10 and M40
Cylinder head cover gasket
O' ring Fuel pump/fuel tank meter
Stabilizer Link Meyle Heavy duty reinforced, right and left side
Stabilizer Link support bracket
Ball Joint Tie Rod
Maneesh
Automaton
Tue Jul 16, 2013 8:20 am
The Weber 32/34 DMTL Carb to replace the Suzuki carb.
Webcon even found me a rubber mount to go with it for an additional Pounds 25.
Maneesh
Tue Jul 16, 2013 11:27 am
Behold, the glory of a new Weber! :D Should make quite a decent improvement in overall running and performance, I imagine. Nice manual choke jobbie, too. 8)
Automaton
Tue Jul 16, 2013 1:19 pm
I am feeling like Hamlet with a skull in hand.
Maneesh
aimlessrock
Tue Jul 16, 2013 1:46 pm
first class mate, i admire the effort.
I had an identical 316 M10 many moons ago and it was a superb all rounder.
best of luck. :D
E30 320i Convertible (1989)
190 Mercedes (1988)
Automaton
Thu Jul 18, 2013 6:25 am
Two steps forward,
51 mm Sachs shocks were the "It doesn't fit', what?!!! How can that be....oh there are different sizes....crap!" shock after lugging them all the way from Thailand.
Found 45mm Monroe in Mumbai and got them in.
Steering rack repair kit turned out to be for an M40 engined car. My Thai was limited to two words, his English was bad. Another shake of the head from teh garage owner, because he was unhappy that I was importing parts, and feeling confident that we could get everything here. Our visit to Opera House and Lamington Road (an area here where all the parts shops are located) proved him wrong. Just got 2 Monroe shocks and old rear wheel bearings, nothing else.
So local guys used what they could from the bunch of rubber seals and the rest off a proper set.
Maneesh
gooner1
Out humping Reindeer
Thu Jul 18, 2013 7:38 am
As a fellow M10 owner, albeit an injection as opposed to carb, I have
nothing but admiration for your doggedness in resourcing parts.
Also loving the Heath Robinson approach to fixing things.
Any help I can give you re obtaining parts, give me a shout and I'll try my best
to help. :thumb:
Rob.
bab-91
Thu Jul 18, 2013 8:20 am
:lol:
After all these packages from the UK, it would have been cheaper to import a mint '30 by envelope! :)
Best of Luck!
Automaton
Thu Jul 18, 2013 9:19 am
Haha Thanks for all the encouragement and support.
I wish import of cars was allowed here. And yes, 10 Pound parts are costing 20 Pounds to ship so my CA is not going to be happy later in the year. After all this, I hope it runs.
Have to admit, had to google Heath Robinson to figure what you meant, and why good cars are 'turds' will always remain a mystery to me :? :o:
Maneesh
gooner1
Thu Jul 18, 2013 10:07 am
" turd" can be term of endearment but also can describe a car as a shed, heap, pile of
crap. Very difficult to explain as it depends on what context it is being used.
On any of my turds, it's usually the latter meaning. :)
Automaton
Thu Jul 18, 2013 10:47 am
I know the other meanings :)
It's just the term of endearment that had me foxed.
Maneesh
SAP1
Fri Jul 19, 2013 1:14 pm
India awesome! What part ?
Automaton
Fri Jul 19, 2013 2:06 pm
Sweaty Mumbai.
Maneesh
SAP1
Fri Jul 19, 2013 3:10 pm
My family's from Gujarat LOL!
Fri Jul 19, 2013 5:10 pm
SAP1 wrote:My family's from Gujarat LOL!
LOL, been there, stayed between Navsari and Surat for 2 weeks
SAP1
Fri Jul 19, 2013 8:12 pm
Acha! Got my fam in Surat lol!
Fri Jul 19, 2013 10:14 pm
I have inlawa in "Vow" if you know where that is???
Place called "Char rasta??
SAP1
Fri Jul 19, 2013 10:44 pm
Yeah ma mum is from Surat and there is a gham vow dunno where inlawa is lol! Yah and char rusta is just between bardoli and Surat
