What do i need to fit an aftermarket HU?
Junglistjed
Post Thu Jul 18, 2013 2:35 pm
Do i need a particular adapter? have a pioneer HU i want to put in but not sure what i need! do i need an aerial adapter as well?
cheers
Morat
Post Thu Jul 18, 2013 2:53 pm
You generally won't know until you take out the existing head unit, most E30s have had their wiring hacked about by now.
Post Thu Jul 18, 2013 3:20 pm
You may find the Zone Wiki useful:
http://www.e30zone.net/e30zonewiki/index.php/E30_ICE
Junglistjed
Post Thu Jul 18, 2013 3:28 pm
Is there a certain adapter i will need if everything is standard?
Post Thu Jul 18, 2013 3:30 pm
Probably; I think the standard E30 looms were designed for 1980s Blaupunkt head units.
trevski
Junglistjed wrote:Is there a certain adapter i will need if everything is standard?
You will prob need to hack it.
Junglistjed
Post Thu Aug 15, 2013 12:55 pm
the cassette player just pulls right out, if i remove the cage, will an aftermarket HU fit correctly? or will i need something to help it fit (like a fascia)
trevski
Post Thu Aug 15, 2013 1:04 pm
Get an after market head unit that has its own cage then just swap them
Junglistjed
Post Thu Aug 15, 2013 1:12 pm
Already have an expensive HU that i want to put in, no cage :( also need to know what sort of wiring loom i will need and if i need an aerial adapter!
