rev counter not working
frenchi
rev gauge not working any idears
Prime suspect is the SI board batteries.
frenchi
you are allways there mate ,what and where are they
Grrrmachine
- E30 Zone Wiki / Team Member
All the information's at your fingertips:
http://www.e30zone.net/e30zonewiki/inde ... ot_Working
http://www.e30zone.net/e30zonewiki/inde ... _Batteries
frenchi
ok changed battery board over from one that was ok,reving and working ,pluged into mine and nothing only when you switch off it flickers.help brian
Grrrmachine
And did you read the "Rev Counter Not Working" page?
frenchi
yep went through that but it did not help.
Grrrmachine
If you've swapped the SI batteries with known good ones, and you're absolutely sure the black wire is giving a clean signal from the ECU to the clock, then either your clock itself is broken or your engine isn't actually turning.
frenchi
thanks for that I understand what you have wrote,i suffer from dislexier .its hard to understand and red some stuff ,I have tried the site but some stuff wont come up I don't think I have the right hard where,i will have another go tomorrow I think the signal is trying to get through that's why the needle was jumping ,thanks again, rick
