rev counter not working
- Brianmoooore
Prime suspect is the SI board batteries.
Grrrmachine
- E30 Zone Wiki / Team Member
All the information's at your fingertips:
http://www.e30zone.net/e30zonewiki/inde ... ot_Working
http://www.e30zone.net/e30zonewiki/inde ... _Batteries
Grrrmachine
And did you read the "Rev Counter Not Working" page?
Grrrmachine
If you've swapped the SI batteries with known good ones, and you're absolutely sure the black wire is giving a clean signal from the ECU to the clock, then either your clock itself is broken or your engine isn't actually turning.
thanks for that I understand what you have wrote,i suffer from dislexier .its hard to understand and red some stuff ,I have tried the site but some stuff wont come up I don't think I have the right hard where,i will have another go tomorrow I think the signal is trying to get through that's why the needle was jumping ,thanks again, rick
