Replacing the pump for washer jets
emmaitch
I need to replace the small pump for the windscreen washer jets, garage tested it and the 'power' is getting through ok. They said its easy to get the pump from any motor factors, but wondered if is better to get a specific E30 unit from a breakers (eg the guys in Charing in Kent)? S'pose it depends, not worth it if its old and about to give up as well - any views?
Grrrmachine
- E30 Zone Wiki / Team Member
From a breakers? They're about three quid brand new. Made by FEBI, fitted to same-era Audis.
Gert_8
£35.00 more like, if it's the pump i think you're talking about...
Either way, a second hand one will be fine. I've never known one fail that hasn't been allowed to freeze.
Grrrmachine
If they're are 35 quid on your side of the Channel then I'll buy these up and do a deal for 20 quid eachGert_8 wrote:£35.00 more like, if it's the pump i think you're talking about...
http://allegro.pl/pompka-spryskiwacza-b ... 39049.html
Postage is more than the part!
Gert_8
Brianmoooore wrote:Postage is more than the part!
Grrrmachine
I've changed the link for something with the correct BMW pins now - price has gone up from 2 to 5 pounds
Gert_8
Buy and send me one at cost, and ill give you £2 for your troubles..
clipper
Remeber that pre / post facelift cars have different connectors to the pump!
Grrr's link has post f/l connector.
Gert_8
Perfect for me!clipper wrote:Remeber that pre / post facelift cars have different connectors to the pump!
Grrrmachine
Might be cheaper just to order from here, no?
http://partsforallcars.com/spares/produ ... _id=160618
Gert_8
Can't see an image Grrr...
Grrrmachine
There isn't one, but that's the part number for the facelift pump.
Gert_8
Great. Thanks.Grrrmachine wrote:There isn't one, but that's the part number for the facelift pump.
