e30 allround race car build
kiwidan
I have managed to get both the headers made in the past few days .
the drivers aide was prtty hard with the room I had and the steering knuckles
but its all done.
but its all done.
kiwidan
its all back on the ground now so I can start on the rear end
kiwidan
now I know where this build id lol
jimmyspeed
cool build, i like your rally style shifter!
but i think the design of your rad scoop may not be ideal, going from what i read up in my turbo book it recommends a smaller mouth (30-60% rad area) tapering out to the full radiator size, sounds counter intuitive but his reasoning was that with that design the air can enter but not leave unless it passes through the radiator - whilst with a large scoop the air will take the easy way out and billlow around the sides,
it also said to use a light ducting material upto two inches from the cooler and then finish with a rubber strip, so not to pierce the radiator during contact during a race
hope thats some use
hope thats some use
kiwidan
thanks for that mate
and what you say is try the rad intake has already been cut so its an inch away from the core and it will just fold and crumble if hit now.
as for the ducting it will lose some air but will feed more than not having it at all as most of the air lower down would have been lost as the radiator is pretty high and now all of the central part of the front will be direted threw the rad.
kiwidan
mmm manual treats
and 3.64 lsd
and 3.64 lsd
kiwidan
diff and axles all in
also took all the stuff not needed off the motor and made some alloy plates to fill the gaps and keep all the crap out..
just running the ALT of the crank now.
befor and after shots
kiwidan
hydraulic release bearing lines made and also made a surge tank
kiwidan
flywheel, clutch, pressure plate, release bearing all done and engine and box back in for the last time.
kiwidan
getting closer to having it all plumbed up and running
rix313
Looking fast
the strut brace looks good I like that, nice and strong, ties in well.
gooseygander110
hello mate .....interesting thread and build ....... a few questions if you don't mind............ My son wants to put the lexus V8 in his MX5....... would you mind giving me some info on the gearbox setup ? What bell housing, adapter plate, clutch set up are you using on the g52 ? also....... if you don't mind .....are the rear wing inserts E36 too.......... deffo following your build
all the best
Gus
all the best
Gus
kiwidan
hi Gusgooseygander110 wrote:hello mate .....interesting thread and build ....... a few questions if you don't mind............ My son wants to put the lexus V8 in his MX5....... would you mind giving me some info on the gearbox setup ? What bell housing, adapter plate, clutch set up are you using on the g52 ? also....... if you don't mind .....are the rear wing inserts E36 too.......... deffo following your build
all the best
Gus
you will find this thread on oldschool very helpful.
http://oldschool.co.nz/2011/forum/index ... -non-vvti/
mine is a 95 1uzfe
*im using a flywheel that I bought here in nz for $300nz
* its made to use a clutch and p.plate form a celica gt4 $250nz.
*1uz auto bellhousing with and adapter plate *200nz (I just made my own)
I looked around for a hydraulic release bearing and the cheapest I found was the howe racing one from summit racing in the states http://www.summitracing.com/parts/hre-82870
as for gearbox yes im using the g52 its cheaper then all the others and some of the guys here in nz are running them in theyer pickups with 1uz motors and havnt broken them yet but they say to use redline lsd diff oil in them....the only thing is they are realy low geared so you will want to run atleast a 3.7 diff.
as for my rear 1/4 panels they are off a fl e30 .
let me know if I can help you ant more.
cheers
dan
kiwidan
oil cooler , radiator and fan and fuel filler all mounted
kiwidan
well I opened the garage door for the 1st time in over a month.
and I managed to get all the rear alloy panelling done.and started to seal it all up
kiwidan
well I thought finding a fat boy seat was hard ....turns out so is fitting the bloody thing between the cage and tunnel.
milescook
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
kiwidan
so we started the 50 odd wire link jobby yesterday.....getting there
rix313
Hedley48
electrics is well beyond me and i wouldnt have the foggiest with that lol, project stopped
very interesting build wish i knew that e36 front arch trick ive just riveted some wide arches on
i do like em though
kiwidan
no hasn't stopped just been stupid busy at work and havnt had any time to get in the garage .
but it does run.
but it does run.
kiwidan
