Indicator and Hazard lights
Mo13
Mon May 20, 2013 2:14 pm
My Indicator and Hazard lights stoped flashing now when I use the its a stedy light instead of the flashing....any ideas?
Cheers,
Mo
Topblag
Mon May 20, 2013 2:37 pm
Broken relay perhaps, sending the power constantly instead of intermittent ?
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Mo13
Mon May 20, 2013 8:08 pm
Any ideas on location of the relay? Cheers
Mon May 20, 2013 8:11 pm
'Relay' is under the cover for the steering column stalks, immediately below the steering wheel, but the most likely cause of your problem is the hazard switch itself, especially if the problem arose after you switched on the hazards.
Easy to open up, clean, lubricate and reassemble.
Mo13
Mon May 20, 2013 8:14 pm
Ahh it was after I used the hazard lights! Thanks Brian I shall give that a go! Any specific lubes?
Mon May 20, 2013 8:36 pm
Electrical contact cleaner first, and when that has dried, a little silicon spray grease.
Mo13
Mon May 20, 2013 8:40 pm
Top stuff! Cheers Brian I shall give it that a go
Mo13
Wed May 22, 2013 3:33 pm
Couldnt find them in the garage.....is brake disk cleaner and wd40 sufficiant of a no no?
Wed May 22, 2013 7:12 pm
WD40 will do for the clean up, but not for a long term lubricant.
zd3bx
Wed May 22, 2013 7:24 pm
Or get another switch from a scrappy for £1 :D
Mo13
Wed May 22, 2013 11:15 pm
Cheers gents I might just do a quick temp clean with the wd40 so I can use it the get some lube or a switch alltogethee
Mo13
Tue May 28, 2013 2:26 pm
dismantled the switch gave it a good clean with wd40 assembled it with all the springs sitting correctly so the switch goes in and out smoothly.........connected it up and - still doesnt work!
looks like I will just have to source a replacement.
Mo13
Sun Jun 02, 2013 12:29 am
Popped down to see Mr andyp to get a replacement hazard light switch when I plugged it in it still did not work!!!
After explaining how the problem came about he wasn’t having none of it and whipped into action wasting no time "man on a mission" in a matter of minutes he took my steering wheel off and swapped out the relay and "hey presto" it worked!
andyp TOP BLOKE!!!
The offender:
Sun Jun 02, 2013 1:33 am
potter is a hero once again :D
Mo13
Wed Jun 12, 2013 12:02 am
Today it has developed another problem....!!! It was working fine and I indicated to go right no lights just a fast ticking noise indicating left works fine and the hazard work fine all the lights come on....any ideas gents? Cheers
Mo13
Wed Jun 12, 2013 11:23 am
Anyone? Fuse maybe?
BenHar
Wed Jun 12, 2013 12:22 pm
Might be a dodgy contact in one of the bulb holders on that side.
Ben
Mo13
Sun Jun 16, 2013 6:04 pm
Cleaned the bulbs/holders still have the same issue! Tries a short cut with a peice of wire and it works.
Would it be the flash unit/relay I've already changed under the steering wheel?
zd3bx
Sun Jun 16, 2013 7:19 pm
Fast ticking is always bulb/contact issue and you normally have one indicator not working.
I get this sometimes myself and after playing around with the bulb and the contacts, it works fine.
Also could be that your light is cracked/damaged and letting water or moisture in, which causes this issue.
PaDz
Thu Jun 20, 2013 12:38 am
Im also having this problem! I changed all the bulbs and they all work, but whenever i use it right I just get the fast ticking. I dont really know much about fuses, is it best to take th steering wheel off and have a look?
Mo13
Thu Jun 20, 2013 2:03 pm
PaDz wrote:Im also having this problem! I changed all the bulbs and they all work, but whenever i use it right I just get the fast ticking. I dont really know much about fuses, is it best to take th steering wheel off and have a look?
All of my bulbs also work, my next call would be the flash unit/relay under the steering wheel - cant think of anything else unelss somone on here knows otherwise.....
PS your avatar is too big.
Thu Jun 20, 2013 3:01 pm
Mo13 wrote:Cleaned the bulbs/holders still have the same issue! Tries a short cut with a peice of wire and it works.
I would suggest it may be because someone has spliced an extra wire into that hazard switch wiring, and it may be causing the issue.
Mo13
Thu Jun 20, 2013 3:08 pm
Is the extra wire you are reffering to the brown one? I put that brown wire in to demontrate the right indicator works from the hazard light switch.
Mo13
Thu Jun 20, 2013 3:09 pm
also it was working fine and just suddenly decided it no longer going to work.......
Thu Jun 20, 2013 3:41 pm
No, I was referring to that red wire with the yellow going into it, with the blue crimp connector.
Mo13
Thu Jun 20, 2013 3:46 pm
hmmm I shall investigate. is there any documentation on the wireing for this?
Thu Jun 20, 2013 10:19 pm
Mo13
Thu Jun 20, 2013 10:23 pm
Cheers, not that I can make any sense out of it lol
Mo13
Sat Jun 22, 2013 11:29 pm
Dig a bit of digging around.....
Swapped over the indicator stalk now it's all sorted!
Mo13
Sat Jun 22, 2013 11:34 pm
Blew the hazard fuse in the process, now the hazard light don't work lol have to wait for tomorrow to get a fuse in!
