chip install
dark_sounds
Post Wed Jan 04, 2006 8:55 pm
anyone got pics or how to install a chip in 318is??
also if i put in the chip dont like it, take it out and put old one bck in,,, it wont ruin anything will it???
Jamesb318is
Post Wed Jan 04, 2006 9:07 pm
Drop down the cover under the steering coloumn (over the pedals etc.) you just turn the screws 90 degrees.
You will see a silver box with a large connector on it under the cover. Loosen the 4 10mm nuts which clamp it in, then it will slide out towards the rear of the car. Unplug the plug (make sure the ignition etc is off).
And remove the ECU (the silver box).
Remove the four torx screws on top of the ECU, and bend the lugs over which are bent onto the bottom.
Take the top cover off, then you will see the chip in question sitting on a raised platform probably with a silver sticker on it.
Lever this off with a screwdriver wrapped in pvc tape or similar and replace with your chip.
If it doesnt work etc, just replace the old one and job done!
dark_sounds
Post Wed Jan 04, 2006 10:13 pm
cheers mate so no damage to the original chip settings wil be had yeah?
E30Mark
Post Wed Jan 04, 2006 11:09 pm
I've had various after market chips in mine, plus i then replaced the original chip back with no consequences...
Takes a few miles for the car to settle down and re learn the settings, but other than that no probs at all.
PM for details
dark_sounds
Post Wed Jan 04, 2006 11:59 pm
thanks alot fellas,, think i might check out a chip tommorow then :)
TheDutch
Post Thu Jan 05, 2006 12:34 am
E30Mark, which chips have you had in? Anything good? I guess not if you've got the original one back in!
