Long trip tomorrow in the heat: can I overtop coolant/oil?
BEERBOY123
Folks, as above, as I've not posted a daft question for some time...
On a long trip tomorrow and it's going to be hot. I'm wondering if I can overfill the oil and coolant?
Or will this cause other problems? What's the worst that can happen if I have too much of either?
(Was going to post in technical, but it barely qualifies!!!)
BEER
BEER
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
toby
No don't overfill, just take spares of both.
Too much oil can create too much pressure, blowing a seal is a possibility. Too much water will just leak out.
Z3I
Can blow a few seals..best keep to the limits.
bmw9818
where are you driving in the middle east? its not that hot in the uk,
BEERBOY123
Good point. Drama queen!bmw9818 wrote:where are you driving in the middle east? its not that hot in the uk,
gooner1
- Out humping Reindeer
Wouldn't worry about the heat, it'll probably piss down tomorrow.
bmw9818
Also dont forget, battery top up water, high vis jacket, spare bulb kit, warning triangle and a whistle and sos light in case of an emergency!BEERBOY123 wrote:Good point. Drama queen!bmw9818 wrote:where are you driving in the middle east? its not that hot in the uk,
aze30
....lol and top oil rite up till it almost flows out the dipstickbmw9818 wrote:Also dont forget, battery top up water, high vis jacket, spare bulb kit, warning triangle and a whistle and sos light in case of an emergency!BEERBOY123 wrote:Good point. Drama queen!bmw9818 wrote:where are you driving in the middle east? its not that hot in the uk,
drain the rad of water before you set off ...it might help you get home before you leave
aze30 wrote: drain the rad of water before you set off ...it might help you get home before you leave
+ a yard full of scrap turds
andyp
- True Old Skooler
don't over fill any of them or you will have problem and be coming home on the back of an RAC or AA truck, top up to the levels and go
p.s. what country do you live in ?
lhd220turbo
Why would you want to overfill anything? would you overfill a bath? would you overfill a kettle? why on earth would you want to overfill it?
it really is quite worry when you see "questions" like this
Curr946
keep filling it with oil until you can see it covering the rockers. you will be fine
If your wife must learn to drive, don't stand in her way!
harry_p
Do you think there might be reasons why bmw in all their wisdom decided exactly where to set the MAXIMUM levels?
cheers,
harry
harry
- **BANNED**
And a crate of beer/champagne to drink whilst waiting on the hard shoulder.bmw9818 wrote:Also dont forget, battery top up water, high vis jacket, spare bulb kit, warning triangle and a whistle and sos light in case of an emergency!BEERBOY123 wrote:Good point. Drama queen!bmw9818 wrote:where are you driving in the middle east? its not that hot in the uk,
TPS
magpie wrote:aze30 wrote: drain the rad of water before you set off ...it might help you get home before you leave
G-Bear
I've read that about five times... I don't get itTPS wrote:magpie wrote:aze30 wrote: drain the rad of water before you set off ...it might help you get home before you leave
gooner1
G-Bear wrote:I've read that about five times... I don't get itTPS wrote:magpie wrote:
Break it down G, break it down.
