bmw 325i turbo head gasket
shane281189
think the head gasket has gone on my e30 turbo , i dont think arps or mls gasket was used what would be the damage on this ?? would i get away with arps and gasket its running 8 psi
ross_jsy
Impossible to say what damage has been done. It has probably just blown past the gasket and the head will be fine but if it's the result of poor mapping causing detonation/overheating then it could be worse.
8 psi isn't that much, you should be ok on the standard gasket with some ARP's.
shane281189
Thanks mate , hopefully I will get away with that . What would you recomend head gasket wise just standard or mls ? Would I need a thicker one because I don't think it has had the compression lowered or am I fine to run standard size ?
I'm new to this and am learning as I go along what is detonation ? I have heard it come up a few times the car was rolling roaded only 2 weeks ago would he of heard or known of this ? Is there a way to tell if so how can I get it remapped anyone in the Essex area that could help out with that ?
scjimbo
Detonation is the point in the stroke at which the fuel combusts. It can be either to early or too late.shane281189 wrote:Thanks mate , hopefully I will get away with that . What would you recomend head gasket wise just standard or mls ? Would I need a thicker one because I don't think it has had the compression lowered or am I fine to run standard size ?
shane281189
How do I know if this is happening ?
ross_jsy
Under high boost/acceleration it will be at it's worse, it will sound like a plinking or ticking sound. If the dyno operator wasn't an idiot he probably would have picked up on it though.
R.E. the gasket, shoot Gunni a PM. He will be able to give you the best advice. Tell him your full set up and see what he advises
ross_jsy
shane281189
Now you mention that I do remember hearing a strange ticking noise never thought it was the engine tho :/ it may just a coincidence i heard that noise but it could be ..... It runs on mega squirt at the moment where could I get the mapping checked or put right to be safe ? Was thinking of sticking a 2.7 in with arps and mls gasket gunna have to now .. I will pm him mate thanks for the advice
ross_jsy
Gunni is recommended for mapping work so best speak to him
shane281189
Cheers mate have pm'd him
