Removal
Fastroad
So I have been thinking as we do not really have a summer over here should I keep or remove the AC and save myself messing with it to get it working?
What would you do??
What would you do??
- **BANNED**
Air Con?
I just drop the top or open the sunroof!
Youth is wasted on the young.
Fastroad
Non sunroof model. Could always open the window
G-Bear
Isn't an AC unit heavy and does it not use up more fuel?
Fastroad
Not sure on how much weight difference there is, but I guess it would be sapping power and fuel
G-Bear
If its not working I'd be inclined to pull it off..
Fastroad
Looks like its going to probably be coming out.
milescook
Can it be repaired? All your switches compressor loom and other guff would sell well here for some tinker to retro fit ac i reckon,or if the major parts are beyond repair the ancillaries would fetch some dosh.
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
jonny323i
Depends on whether its a dealer or oem fit I'd love to have an. E30 with working aircon I have the aircon just not working
Touring for life
Grrrmachine
- E30 Zone Wiki / Team Member
If you're going to remove it, you'll need to seal up all the pipes as soon as they're disconnected. If they're in good condition they're worth loads - 24 hours later, they're scrap due to the moisture inside causing rust.
So if you're going to dismantle it, do it properly and you can make some serious cash. Is it R12 or R134a?
scrap it out ,it's heavy and steals fuel .
buy a heated front seat retro fit kit instead,far more appropriate in this climate .
+ a yard full of scrap turds
Fastroad
Fastroad
I agree with the heated seats option.magpie wrote:scrap it out ,it's heavy and steals fuel .
Grrrmachine
Simplest way to check is to look at the compressor (bolted to the engine block below the exhaust manifold) or to check the part number of the receiver/drier (the black round filter thing that bolts into the right-hand inner wing behind the headlights).
R12 is illegal in the EU so it won't be worth as much, but a conversion kit to R134a is available from BMW.
