Right, enough of the dodgy innuendoes.
Depending on how I have my hand on the gear shift, changing up 2nd - 3rd and 3rd - 4th I can remove the top, it is usually when I'm doing slightly aggressive shifts.
When I stripped things down it was really hard to remove the shifter knob, like, I had to put he-man strength into it. Now though it comes off with shifting which really isn't good.
I know one of the answers is "don't shift aggressively" but the main thing is, it shouldn't be coming off so easily.
Any ideas as to what I can do to sort this? I could replace it as that should have a tighter connection to the stick but I'd rather not spend when it is only an occasional issue.
