exhaust
daneilhussain
Post Tue Apr 09, 2013 8:12 pm
hi ya guys ive got a rusty e30 exhaust on my e30 and ive got a spare scorpion exhaust im a lack of mechanic but just wounding would a good 30mins on the drive way be possible to replace the back box or are they welding and any cutting needing or if someone car send me a page step by step ta
Rtaylor2208
Post Tue Apr 09, 2013 9:05 pm
Engine size and what exhaust you have would be helpful?
Quaser
Post Tue Apr 09, 2013 9:10 pm
If im correct, you have a mtec2 sport - usually this would have a 2 piece system
Scorpions usually are 3 piece systems - so you may need to get an exhaust place to weld it on or create pipes - or get the centre and front pipes to do it urself.
otherwise its an easy job probably 1 hour or so
daneilhussain
Post Tue Apr 09, 2013 10:45 pm
mines a scorpions back box mate its got 2 pipes same as the exhaust on it and yes its a 325 tec 2 would u think its simple unbolt and bolt on ?? if so mostly would u think i would be able to do it on the driveway or should i just pay a mech to do the work as i wanted to do everything on my e30
Rtaylor2208
Post Tue Apr 09, 2013 11:26 pm
The key thing is if its a 2 or 3 piece exhaust.
You will need to get under the car to know for sure as there is no hard and fast rule as to what cars have a 2 or 3 piece system at this age as it could have already had attention.
If you have a 2 piece fitted and the scorpion box is for a two piece system it should just bolt together. But if one is a 2 piece and the other a 3 piece you will need the pipes extended which will take some work from an exhaust place.
daneilhussain
Post Tue Apr 09, 2013 11:54 pm
o ok when u meen 2 3 piece my back box on the scorpion that connects to the rest of the exhaust has 2 pipes same as the back box on it based on that would that mean its a 2 piece n would u say doing it myself would be easy if not il just drive it down worst case if ifuck it up
Rtaylor2208
Post Wed Apr 10, 2013 9:32 am
No, the exhaust on a 325i can come in two or 3 sections. A 2 piece exhaust front section is connected to the manifold at the front and the rear section connects to the front section.
A 3 piece system has a downpipe from the manifold, a mid section and a rear section.
The back box for a 2 piece looks like this:
http://www.ebay.co.uk/itm/BMW-3-E30-2-0 ... 23094e8e27
And a 3 piece has much shorter pipes where it would connect to the middle section.
kman82
Post Thu May 16, 2013 2:14 pm
just out of interest, does a 2/3 piece exhaust include the manifold or not?
i.e. is it manifold + 2/3 other sections? if that makes sense :mad:
Rtaylor2208
Post Thu May 16, 2013 2:19 pm
A 2 piece does not include the manifold. Basically the front section connects to the manifold and runs to the middle of the car, the back piece is the backbox.
I believe the 3 piece is downpipe from the manifold, center and rear sections.
Quaser
Post Thu May 16, 2013 2:24 pm
yep -
manifold + front section + rear section = 2 piece
http://www.ebay.co.uk/itm/BMW-E30-Super ... 111wt_1359
http://www.ebay.co.uk/itm/BMW-325-3-SER ... 315wt_1359
manifold + downpipes + centre section + rear section (shorter) + 3 piece)
kman82
Post Thu May 16, 2013 2:39 pm
cool, cheers
