another find just sat there 323i rare BBS bodykit
those are my plans for the next attempt + fuel check .i'll just splice into the pump live feed under the seat and give it 12v direct ,we'll sharp find out if the pump is still alive
+ a yard full of scrap turds
kangman
more detailed pics of this breaker
MY FACEBOOK PAGE- CLASSIC STANCE
http://www.facebook.com/pages/Classic-S ... 6444884427
MY FOUR EYED BEAST
MY FOUR EYED BEAST
Kedge
10 year old petrol is going to be useless, get some fresh in there! Hope you've not fucked the bores or anything else internal if you've just tried starting with no other prep work.
plugs out and oiled up the bores on weds gone then turned the crank with a spanner today before i hooked the battery but couldn't be arsed to type that earlier .
i've played with cars for over 20 yrs btw .
jonny323i
I have an old jettronic arm if you need one to bring it back to life
Touring for life
jonny323i
Touring for life
kangman
PM'd
MY FOUR EYED BEAST
MY FOUR EYED BEAST
i removed the underdash panel this morning to check things are plugged in and to hook a live feed up from the ignition for the fuel pump.I found the foxgaurd immob on the back of the panel and a secret switch that i hope is a fuel pump cut off as this was a common practise back in the day up here in twoc central!
i'll have to try to start it again tomorrow as the day will be mostly taken up by fixing other peoples turds
are the con rods/pistons from these any use for a stroker ?
i'm sure i've asked but can't find the post now
The 323i crank has a longer stroke than the 325i one, so theoretically, you could use it to make a stroker:
http://www.e30zone.net/e30zonewiki/inde ... ding_a_2.7
I gather the 323i piston bore, cylinder head and conrods are the same as a 320i.
BEERBOY123
SAVE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
it was last reported on it's way to china ,bon voyage
jimbom30cab
- Tech 1 freak
make much profit on that one Mick?
glad i saved the 3.46 diff
nah not a bean matejimbom30cab wrote:make much profit on that one Mick?
jimbom30cab
- Tech 1 freak
top man
