another find just sat there 323i rare BBS bodykit
Post Sat Feb 16, 2013 4:50 pm
those are my plans for the next attempt + fuel check .i'll just splice into the pump live feed under the seat and give it 12v direct ,we'll sharp find out if the pump is still alive :D
kangman
Post Sat Feb 16, 2013 7:03 pm
more detailed pics of this breaker :D
Kedge
Post Sat Feb 16, 2013 7:15 pm
10 year old petrol is going to be useless, get some fresh in there! Hope you've not fucked the bores or anything else internal if you've just tried starting with no other prep work.
Instagram - Kedge85
Post Sat Feb 16, 2013 7:35 pm
plugs out and oiled up the bores on weds gone then turned the crank with a spanner today before i hooked the battery but couldn't be arsed to type that earlier .
i've played with cars for over 20 yrs btw .
jonny323i
I have an old jettronic arm if you need one to bring it back to life
Touring for life
jonny323i
Post Sat Feb 16, 2013 7:37 pm
Touring for life
kangman
PM'd
Post Wed Feb 20, 2013 9:31 am
i removed the underdash panel this morning to check things are plugged in and to hook a live feed up from the ignition for the fuel pump.I found the foxgaurd immob on the back of the panel and a secret switch that i hope is a fuel pump cut off as this was a common practise back in the day up here in twoc central!
i'll have to try to start it again tomorrow as the day will be mostly taken up by fixing other peoples turds :(
Post Sat May 11, 2013 9:33 am
are the con rods/pistons from these any use for a stroker ?
i'm sure i've asked but can't find the post now :?
Post Sat May 11, 2013 11:15 am
The 323i crank has a longer stroke than the 325i one, so theoretically, you could use it to make a stroker:
http://www.e30zone.net/e30zonewiki/inde ... ding_a_2.7
I gather the 323i piston bore, cylinder head and conrods are the same as a 320i.
BEERBOY123
Post Sat May 11, 2013 8:48 pm
SAVE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
Post Sat May 11, 2013 11:09 pm
it was last reported on it's way to china ,bon voyage :D
jimbom30cab
Tech 1 freak
Post Sat May 11, 2013 11:13 pm
make much profit on that one Mick?
glad i saved the 3.46 diff :)
Post Sat May 11, 2013 11:31 pm
jimbom30cab wrote:make much profit on that one Mick?
nah not a bean mate :wink:
jimbom30cab
Tech 1 freak
Post Sat May 11, 2013 11:34 pm
top man :thumb:
