It seems to have developed a nasty habit now that the central locking works...it will unlock itself. I *think* it is due to the locks being gummy and needing a rebuild, do need to investigate that as having an unlocked car isn't ideal.
Locked it.
1988 325i Cabriolet - Gone.
Replaced my throttle cable, because the old one snapped on the M5 yesterday
Stupid Weber 'universal' throttle cable attachment, biggest POS ever. May also be because I never bought a manual throttle stop and kept my auto one, making it essentially impossible to set a WOT position
milescook
- Contact:
Tried again to get a secure garage fir its move down to the valleys from my old place near in cambs . Gumtree bringing up loons so far like the person that responded to my request to take a look with 'ok thanks ill have a look!'. The second was aautomated reply telling me i was to pay them a referral fee and gave the guys number.who hasn't bothered to return my voicemail.
So in short bugger all as iTa miles away
Also please help the race budget by watching some videos
https://www.youtube.com/cookracinguk
washed it and now im just waiting for it to rain
MY FACEBOOK PAGE- CLASSIC STANCE
http://www.facebook.com/pages/Classic-S ... 6444884427
MY FOUR EYED BEAST
MY FOUR EYED BEAST
billgatese30
Yesterday I washed the sport (for the first time in what seems like ages) and today I was going to sort out one or two minor jobs and hoover the interior etc however...rain stops play
Removed the hardtop, delighted to find the electric hood worked fine after 4 months in hiding, and went for a top down tour along the Darenth valley in Kent. Also enjoying the newly fitted MTech 2 that replaced the old 'bus driver' wheel...
e30nerd
- Contact:
My weekends work was:
Fitted front discs and pads.
Rear ARB drop links
Fitted new headlight dimmer switch
Replaced side light bulb
Sorted out central locking issue
Washed it
Hopefully ready for MOT on Wednesday
Rear ARB drop links
Washed it
fitted my illuminated gear know and leather gaiter, cleared the elephant trunk which should hopefully get rid of the annoying leak to the passenger foot well.
fixed the washer jet, changed over the instruments so i now have working petrol, temp etc. and then gave it all a good clean out ready for the MOT tomorrow
jimbom30cab
- Tech 1 freak
Took all the springs off the cab ready to deliver to another zoner tomorrow, fitted new rear springs and found out my sparing compressor is not long enough to compress the front springs enough.
Rtaylor2208
Power steering fluid flushed and changed, oil and filter changed, fuel filter changed, coolant added and fired up for the first time in 3 months. Fooker is being a PITA to bleed as usual.
But not bad for just over an hours work. By some miracle it may even be ready for an MOT by Saturday.
Morat
Discovered that Bottletops are faster than BBS over the potholed and cratered excuses for roads that we have round here. Once the winter has beaten the crap out of the pothole patches, the farmers drive huge tractors and 20 ton trailers over the wreckage until you need 65 section tyres to keep your fillings in place.
Plus I don't care if I buckle Bottletops because I've got three sets
Put a new fuel tank in it
- gooner1
- Out humping Reindeer
Rear springs turned up today, finally.
So set about fitting them. Just as well I did.
This is what faced me after removing the wheel. Dickhead PO.
Cable ties are my handiwork, to help remove the spring.
Was sitting like this before spring change.
Now sitting this way.
Possibly need to do the fronts, but hope the rear drops a lot over the next few days.
Suprisingly not a bad ride even with the rear that high.
Rtaylor2208
Gooner is that what they call rake
- E30 Zone Meets/Events Team
- Contact:
Mine sits like that now Rob, proper 4x4gooner1 wrote:Rear springs turned up today, finally.
What would have caused the spring to jump out of its mounting like that, I wonder?
My chromey 320iSE failed an MOT because it had cheap lowering springs fitted by a PO, which had warped, although it still drove OK; I refitted an original set of BMW springs from my first chromey 320i that had been stored in the garage after I had that lowered.
