http://www.ebay.co.uk/itm/BMW-E30-E34-E ... 35b29bcf3c
I have a prefacelift M20B20 and a facelift M40B18. Will this be the correct tool? Or will I need a 16 pin job?
TIA.
Will this work on all E30?
Cloggy Saint
kitch
For the sake of a few quid I don't mind buying one of these. Just not sure if I need a 20 or 16 pin one.
capnmchl
Probably both. You can get ones with both sockets on them.
As above, why waste your money when a bit of wire or a paperclip will do?
gooner1
- Out humping Reindeer
Cloggy Saint wrote:You need a short piece of wire, nothing else.
Plus this http://www.e30zone.net/e30zonewiki/inde ... ostic_Plug
and this http://www.e30zone.net/e30zonewiki/inde ... ion_Lights
FinalD
Thirded.capnmchl wrote: As above, why waste your money when a bit of wire or a paperclip will do?
I reset all my service lights just before it was MOTed as I'd changed everything so it didn't need to say 'SERVICE ME' any more.
1988 325i Cabriolet - Gone.
kitch
Doesn't seem to work.gooner1 wrote:Cloggy Saint wrote:You need a short piece of wire, nothing else.
gooner1
kitch wrote:Doesn't seem to work.gooner1 wrote:Cloggy Saint wrote:You need a short piece of wire, nothing else.
The links or the actual resetting?
If the latter it may well be your SI board batteries need renewing.
Grrrmachine
- E30 Zone Wiki / Team Member
The device you linked to is simply the Rube Goldberg version of Cloggy's solution. If you want to pay someone money for that, go ahead.
kitch
The actual resetting. I guess I'll have to try replacing the batteries.gooner1 wrote:kitch wrote:Doesn't seem to work.gooner1 wrote:
BATTS91
Try earthing the the battery instead . Ie pin 7 to battery earth as pin 19 didnt work for me either . Works fine for me , done it twice .
