M50 inlet manifold gaskets worth replacing?
I will be removing the inlet manifold to change my starter motor. Is it worth replacing the gasket seals or do they generally not need replacing?
E30-Doc
do you have any vacuum leaks? Did you replace them when you fitted the motor? if no leaks and you replaced them before then I would leave it. Otherwise this might be helpful.
ross_jsy
Had mine off and on 3 times with no problems on the original gaskets
Thanks Ill leave it then.
