M50 inlet manifold gaskets worth replacing?
Post Tue Apr 23, 2013 12:36 pm
I will be removing the inlet manifold to change my starter motor. Is it worth replacing the gasket seals or do they generally not need replacing?
E30-Doc
Post Tue Apr 23, 2013 1:44 pm
do you have any vacuum leaks? Did you replace them when you fitted the motor? if no leaks and you replaced them before then I would leave it. Otherwise this might be helpful.
ross_jsy
Post Tue Apr 23, 2013 2:20 pm
Had mine off and on 3 times with no problems on the original gaskets
Post Tue Apr 23, 2013 4:51 pm
Thanks Ill leave it then.
