My new E21
verde
Post Wed Apr 10, 2013 1:18 pm
Gert_8 wrote:Just go with your plan, Verd. All you're after is a good running car, which is cheap to insure. Get the lump sorted, in the order Pete has advised. :D
Pete and Andys advice is priceless. I have ordered fuel filter, oil filter, looked into shocks ( the suspension is harrowing ) its fine just veeeeery soft. I have oil there. I need to do something with the clutch, slave cylinder i think is fucked. But this weekend I will try the washers and see about replacing the cog
Raise hell praise Dale.
capnmchl
Post Wed Apr 10, 2013 1:19 pm
Grrrmachine wrote:I never did the Wiki M10 Chain guide because I was told it's 10x easier just to swap in a new lump if the chain on the old one lets go.
Wondering if it's worth doing that or converting to fuel injection at the same time to liven the engine up a bit.
The problem with injection is you're set at a certain performance, which you can far exceed with different piston, cylinder head and carb variations, and is why the earlier 2 litres make so much more power, and why the Americans love them. Obviously though cost becomes a major factor in all of it, so to get 170hp, it's far cheaper to just stick an M20b25 in it.
Post Wed Apr 10, 2013 1:22 pm
Theres nout wrong with the engine, its just been sat for a bit and needs serviced and tightened. I did consider a swap but remember insurance costs. I was slated and ripped into for putting an M20 into my 316, now the same folks are suggesting M52s and M42s. As for more power - 4 branch and GSXR1100 bike carbs can be done for like 300 pounds
Ignore the engine swap / modding 'experts' whose expertise is spending your money . LEAVE IT STANDARD !
With the rocker cover off the condition of the chain and top sprocket should be easy to check.
If you buy a new chain with a a split link (most come like this) you can join it to the old one and wind it around. No need for sumps or bonnets off or any of that b0llox.
Unless the bottom sprocket is really foooked , leave well alone, changing it will add a whole load of aggro and pain to a relatively straight forward job.
The timing marks are pretty obvious and as long as you are careful and mark everything, you can not really go wrong.
PS When/ if undoing the cam sprocket, be sure to stick a lump of rag in the front cover to prevent any bolts etc falling into the sump...... :(
BATTS91
Post Wed Apr 10, 2013 2:52 pm
Cable ties and cam chain = fookin winner ! :D
Andyboy
Alpina Colada
Post Wed Apr 10, 2013 6:34 pm
What I would also do with the cam cover off: buy two new copper washers, remove the banjo bolt, twist the spray bar through 180 degrees with grips and drill the oil holes out with a 1mm drill. This will put a lot more oil on the cam and extend it's life, and can quieten down a noisy one. Wash the banjo and the thread in the cylinder head with carb/brake cleaner and tighten it to be moderately tight. Not sure what the torque figure is.
verde
Post Wed Apr 10, 2013 7:46 pm
Andyboy wrote:What I would also do with the cam cover off: buy two new copper washers, remove the banjo bolt, twist the spray bar through 180 degrees with grips and drill the oil holes out with a 1mm drill. This will put a lot more oil on the cam and extend it's life, and can quieten down a noisy one. Wash the banjo and the thread in the cylinder head with carb/brake cleaner and tighten it to be moderately tight. Not sure what the torque figure is.
Thats a genius idea!! Do you do it with all cars or is it just the m10 that needs it?? il do it this weekend. Thanks Andy thats a gem
ross_jsy
Post Wed Apr 10, 2013 8:09 pm
The couple of m20 heads I have rebuilt I have replaced the spray bar.
Is it the m30 spray bar some people crimp in the middle to raise the squirt pressure?
Post Wed Apr 10, 2013 8:12 pm
Yes Ross, M30 one gets squeezed
Andyboy
Alpina Colada
Post Wed Apr 10, 2013 8:46 pm
There's no need - flow is all you need and the M30 oil pump is powerful enough to flow a lot of oil. Crimping the middle doesn't hurt I guess.
Post Wed Apr 10, 2013 8:49 pm
It was to helpflow oil to the rear of the M30 head Andy
capnmchl
Post Wed Apr 10, 2013 9:54 pm
What do you mean twist through 180 degrees? I bought a new one to put on mine, which sounds pretty awful sometimes. Still waiting on a cam sprocket, although the noise does seem to be coming from the middle of the rocker cover.
verde
Post Mon Apr 15, 2013 10:14 am
More pictures and videos to come today hopefully. I installed a new exhaust.....
snakebrain
Post Mon Apr 15, 2013 11:20 am
No, you soldered a crack pipe to the bottom of it... winkeye
verde
Post Mon Apr 15, 2013 11:24 am
snakebrain wrote:No, you soldered a crack pipe to the bottom of it... winkeye
Youve seen it? ;)
gooner1
Out humping Reindeer
Post Mon Apr 15, 2013 11:31 am
Andy means, leave one end attached,the end nearest the Radiator, then move the unattached end of the spraybar round , again towards the radiator,so that it is now clear off the cylinder head, then drill your holes.
verde
Post Mon Apr 15, 2013 2:29 pm
OK bring forth the abuse
Idle - very quiet - quieter than the broken back box i had
1-2.5k mere burble to small drone
3.5k begins to rip
4k+ roaring pretty wildly - lift off the gas and you get over run and popping
Todays task - Finally find that fucking air leak and get the juddering fixed.
do the timing
work done thus far
oil + filter and fuel filter changed, jets cleaned, engine addetive run through, distributor cap looked at, plugs checked, tappets checked, carb tweeked a bit, rear silencer " fixed "
New bushes being ordered, timing to be done, new dizzy and HT leads, new shocks and springs are a priority
Nobby_N
Post Mon Apr 15, 2013 2:43 pm
verde
Post Mon Apr 15, 2013 2:45 pm
haha yeah pretty much, just way less nuts
Im surprised about the effect its had. The car revs much free-er and it more willing to accelerate( guess the crap is getting out quicker ) all i need now is to get the fecker running smoothly
Nobby_N
Post Mon Apr 15, 2013 5:01 pm
Get some more Videos up..... including your mum ! :D
verde
Post Tue Apr 16, 2013 12:10 pm
Waiting on James in car videos being upped.
verde
Post Wed Apr 17, 2013 5:28 pm
Post Wed Apr 17, 2013 6:02 pm
verde wrote:Image
Looks like a dogging spot. Any luck ? :)
verde
Post Wed Apr 17, 2013 6:12 pm
Hopefully next time ;)
Post Wed Apr 17, 2013 6:29 pm
I'd lose the 316 badge, not only for a cleaner look, but also so that parking wardens don't know what it is if you get nabbed. :wink:
rh306
Post Wed Apr 17, 2013 6:40 pm
..some 'factory deepdish' steels would look good too :cool:
Post Wed Apr 17, 2013 6:46 pm
Hasn't he got those fitted already? :?
verde
Post Wed Apr 17, 2013 6:47 pm
Yeah thats exactly whats on there :P I dont like em much.
Thanks for the hint Maurice. I deffo need to get shot of it :P
rh306
Speedtouch wrote:Hasn't he got those fitted already? :?
looks like the narrower ones? Might just be the angle though :squint: They came in 5 1/2" and 5" flavours IIRC?
verde
Post Wed Apr 17, 2013 6:51 pm
The fronts are narrower
rh306
Post Wed Apr 17, 2013 6:57 pm
..the 5 1/2s definitely look a lot better than the 5s.. Spray some felgensilber on them and see what you think before you bin them, freshened up with fresh badges they look a lot better :)
verde
Post Wed Apr 17, 2013 7:49 pm
Il see, I dont have money to spend on aestetics just now. Luckily a friend helped me out so my borbets didnt go far and will be returning home, so theyl go on for a while. When i get another job itl be going on schmidt th lines.
i might have silver paint to tart these up but i certainly aint buying new badges for em.
verde
Post Thu Apr 18, 2013 10:07 am
For those demanding footage. Heres James clips of a little Sunday jaunt
[youtube][/youtube]
Rich320I
Post Thu Apr 18, 2013 3:33 pm
hope your feeding that wheel through verde, sure i just witnessed some arm crossing in that video :)
nice looking motor though, good your finally on the road
verde
Post Thu Apr 18, 2013 3:41 pm
Steering that car with its worn bushes is very much like wrestling a bear, its every man for themselves using any means possible :P Thanks though man, its not a bad wee motor at all
gooner1
Post Thu Apr 18, 2013 3:52 pm
verde wrote:Yeah thats exactly whats on there :P I dont like em much.
What size are your wheels Euan?
