vacuum m10
christo
Post Mon Apr 08, 2013 9:53 pm
Hi lads I am looking for your help as i have a small vacuum pipe that has come undone under the dash drivers side and i cant see where to reconnect it help please? cheers christo.
DHFiS
Post Tue Apr 09, 2013 6:03 pm
It's not the pipe to the headlight height adjuster is it?
christo
Post Tue Apr 09, 2013 9:40 pm
no it is 316 m10 pierburg carb and the pipe comes from carb into bulkhead through rubber grommet on drivers side after that i dont know where it goes??? cheers christo.
Post Tue Apr 09, 2013 11:42 pm
Been a very long time since I played with one of these still fitted with the Pierburg, and the memory is hazy! Most have long since had these replaced by a purely mechanical Weber.
The only part of the engine control on these that is inside the cabin is the primitive ECU that controls the carb. I can't remember any vacuum pipes, but if there is one going into the cabin area, it can only be going to this ECU.
christo
Post Wed Apr 10, 2013 8:51 am
Thanks B.
christo
Post Wed Apr 10, 2013 10:39 am
still no joy any ideas?
capnmchl
Post Wed Apr 10, 2013 11:51 am
It either goes to the ECU or something to do with the dashboard. I might be wrong but it may be something to do with the fuel economy gauge.
Mine has become disconnected as well, but I run a Weber so it's not a problem. Unbolt the ECU and see if it goes into the back of it or up around it somewhere.
christo
Post Wed Apr 10, 2013 2:13 pm
No why i think it is a vacuum problem is because when i start the car it is sluggish and this only happend since the pipe has come undone?
verde
Post Wed Apr 10, 2013 2:53 pm
christo wrote:No why i think it is a vacuum problem is because when i start the car it is sluggish and this only happend since the pipe has come undone?
My e21 has what i suspect is a vacuum issue, and im wondering whether i should check for this pipe too. I have no idea where it should go though
Raise hell praise Dale.
votivequagmire
Post Fri Apr 12, 2013 1:36 am
My previous E30 was an M10 carb, and that vacuum pipe was fixed to the back of the clocks in the dashboard. IIRC it is to do with the fuel economy gauge. You'll need to remove the clocks to reattach it.
'88 325i M20, could've done with a sunroof.
christo
Post Thu Apr 18, 2013 12:05 pm
the economy is still working so its not for that any other ideas??? cheers.
capnmchl
Post Thu Apr 18, 2013 8:01 pm
Tbh, my economy gauge still moves, and I don't even have an original carb in there, or that vacuum line connected. I assume it simply takes the speedo and rev counter pulses as a base measurement. I expect it's the only E30 that say's it does more MPG at 90 than 70.
