Headlight stopped working
FinalD
Post Tue Apr 09, 2013 1:44 pm
So at the weekend I swapped my lights over from one smiley Bosch & one bullseye Bosch to a set of smoked smiley Hellas.
The Hellas had cabin adjust on them but the car doesn't have the rest of the system (it appeared to be duff so I didn't pull it from the doner) so I swapped the manual adjusters from the Bosch units to the Hellas.
I had previously fitted the Hellas and all of them worked fine.
Last night I figured I should probably adjust the beams to ensure I'm only blinding other road users and not low flying aircraft only to find that the drivers side dipped lamp isn't working. I checked the connections, all solid, changed the bulb and it still doesn't work.
I don't know if I knocked or damaged a ground connection or something when changing to manual adjusters, all appeared to be correct and fine though.
Any ideas?
Post Tue Apr 09, 2013 2:01 pm
Fuse would be an obvious place to start.
FinalD
Post Tue Apr 09, 2013 2:31 pm
Are they fused individually?
Passenger side one works fine, just not the driver side. The main beam works as does the sidelight.
BenHar
Post Tue Apr 09, 2013 2:35 pm
FinalD
Post Tue Apr 09, 2013 3:22 pm
That's a yes then. :P
Fuse 14 which is 7.5A...shall check that out tonight before pulling the whole unit from the car. Might well have blown it actually thinking about it as the + cable wasn't plugged into the bulb when I looked at it last night so might have shorted on the - cable/connection.
**BANNED**
Post Tue Apr 09, 2013 6:28 pm
A week or two back I traced an intermitant headlight to a faulty earth connection...
Started at the correct fuse and worked through the system,fitting a new earth wire finally fixed the blighter! :D
Youth is wasted on the young.
FinalD
Post Tue Apr 09, 2013 6:51 pm
Just went and had a look, fuse was blown. I think it blew just because the + cable wasn't connected to the bulb last night before I turned them on. Oops.
Typically, I don't have any spare 7.5A fuses at the moment so will need to pick some up tomorrow.
Looks like it was just a muppet error this time. :D
