Questions
adam_2922
Post Tue Apr 09, 2013 1:09 pm
Firstly are the standard brake disks on an e30 vented?
Secondly what is the code on a limited slip disk on an e30, a friend of mine insists that my car has an LSD, I drive it and insidt that it hasn't.
Also what is the lowest ratio LSD that you can get for an e30 (without ordering specially)
Finally how much will it cost to get a garage (or just a person that knows what they are doing) to fit a set of coilovers. I live in london. Does anybody have any recommendation on kit aswell? I have just fitted new wheels (replaced the horrible buckled aftermarkets) and now the nose looks like it's scared of the road. I only use the car on the road it is a 1991 318i cab so theres no need for the suspension to be too advanced.
Thanks alot
Rtaylor2208
Post Tue Apr 09, 2013 1:14 pm
Only on the 51mm Strut type cars I believe, i.e. 325i, 318is.
it will depend on whether they are the type that need to be welded to the strut or are direct replacement for the inserts.
Fitting a set of good quality springs and dampers will get your car lower and will handle perfectly well. Eibach pro kit, H + R Cup kits come recommened for the springs, and matched to Blistein B4, B6, B8 or Boge Turbo dampers.
Spings and dampers are easily done with a jack, stands and some basic tools. If you know what your doing the fronts can be done in approx 2 hours and the rears in an hour.
Rtaylor2208
Post Tue Apr 09, 2013 1:18 pm
Lots of info in the wiki as well.
http://www.e30zone.net/e30zonewiki/inde ... akes#Discs
http://www.e30zone.net/e30zonewiki/index.php/Suspension
P.S. Getting a garage to do the work very few people can tell you a price as it will all depend on the garages hourly rate.
adam_2922
Post Tue Apr 09, 2013 1:26 pm
Thanks for the info. The wiki is very good
Chris_B86
Post Tue Apr 09, 2013 1:31 pm
To check if your has an LSD, jack the rear end of the car up, spin one rear wheel, if the other wheel spins the opposite way, it's an LSD, if they spin the same way it's an open diff. I'd be very surprised if a 318i has an LSD though, unless it's been retro fitted
j2b
Post Tue Apr 09, 2013 1:34 pm
this ^^^ :cool:
your car being a cab it should already have the 51mm struts fitted
the discs are easy to change too.
89 more door 6 pot
adam_2922
Post Tue Apr 09, 2013 1:35 pm
South east. I live in beckenham.... And it may be a turd but it's not rusty anymore! Its just spend two months in the bodyshop!
The car before I bought it has had a few bits retrofitted. It has vented disks front and back. Battery moved to the rear ect.... And it was probably the person who did this that made the engine need rebuilding!
j2b
Post Tue Apr 09, 2013 1:42 pm
Chris_B86 wrote:To check if your has an LSD, jack the rear end of the car up, spin one rear wheel, if the other wheel spins the opposite way, it's an LSD, if they spin the same way it's an open diff. I'd be very surprised if a 318i has an LSD though, unless it's been retro fitted
think you"ll find its the other way around .
if turning one wheel and the other goes in the same direction =lsd,
if it spins opposite = open diff.
89 more door 6 pot
Post Tue Apr 09, 2013 1:45 pm
Chris_B86 wrote: spin one rear wheel, if the other wheel spins the opposite way, it's an LSD, if they spin the same way it's an open diff.
You might want to try again on that one!
Chris_B86
Post Tue Apr 09, 2013 1:48 pm
Oops my bad, losing the will to live at work, half asleep
capnmchl
Post Tue Apr 09, 2013 2:03 pm
Plus it only really confirms it if the car is in gear when you spin it. Otherwise you may end up spinning the whole carrier which will spin the whole lot one way.
polsta
Post Tue Apr 09, 2013 2:21 pm
also, the LDS will have a little metal tag on it- wire brush it if grubby to reveal the serial number, lsd start with "S" , bit like doing a scratch card really :D
Post Tue Apr 09, 2013 2:58 pm
lsd tests are free here :D
adam_2922
Post Tue Apr 09, 2013 3:05 pm
not with a brand new set of toyo's on they aren't!! winkeye
Chris_B86
Post Tue Apr 09, 2013 3:06 pm
adam_2922 wrote:not with a brand new set of toyo's on they aren't!! winkeye
It'll just scrub them in for proper use
Post Tue Apr 09, 2013 5:49 pm
i do the tests for free :roll: :mad: :P
ross_jsy
Post Tue Apr 09, 2013 5:55 pm
Jack one side up with the other wheel on the ground, car out of gear and turn the wheel that's in the air. If it doesn't turn/hard to turn it's a slipper.
There are figures available somewhere to check if your LSD is within factory specs with a torque wrench. Most aren't any more.
**BANNED**
Post Tue Apr 09, 2013 6:21 pm
All factory cabbies have vented front discs.
Solid front discs only on 316/316i saloon,these could include a Baur conversion.
318i cabbie with manual 'box should have a small case 4:27 diff,I think,cannot recall hearing about an LSD in this ratio.
318iS had LSD as option,on a 4:1 ratio.
Youth is wasted on the young.
