e30 allround race car build
kiwidan
Wed Feb 27, 2013 2:29 am
hi all
this is my 1987 pfl e30 was a 320i.
im building it as a alrounder i can take to drift days ,track days ,road race events and the major 1 for me sealed hill climbs.
heres the specs so far
heres whats been done so far.
*full cage ,
*booster has been mounted inside the car with rebuilt 325i mastr cylinder
*e36 325i front hubs discs and rebuilt calipers.
*e36 coilovers with e30 camber/caster adjustable top hats.
*e36 m3 front control arms with ne bushes
*21mm swaybar with new bushes and swaybar links.
*tree house racing offset mounts
*front guards are e30 with e36 lip inserted (makes the lip 10mm higher and 15mm wider
*10mm spacers upfront and 17x8 rims.
at the rear we have
*e30 subfrmae.
*e36 ti rear control arms with e36ti discs and rebuilt calipers.
*gaz coilovers with damper ajust.
*20mm spacers and 17x8 rims.
*rear guards and been tubber and a new outer skin will be welded on.
*will be full fl bumpers and headlights
so thats about it for now heres some pics
cheers
BATTS91
Wed Feb 27, 2013 2:48 am
cool stuff , few things there that ill be doing ie e36 hubs ect . i must ask tho what is the deal with your front wings ? :cool:
kiwidan
Wed Feb 27, 2013 2:57 am
they are the standard e30 wings with a section out of a e36 wing welded in.
the swage line lines up and it means the lip is 10mm higher and 15mm wider than standard e30.
just means i can get the car lower and run a wider tyre.
cheers
BATTS91
Wed Feb 27, 2013 3:01 am
now that is genius ! not seen that before . solves a few issues, where did you get that idea from ?
will sure look better than rivet on arches as i intend to do
kiwidan
Wed Feb 27, 2013 3:39 am
i guy i knew worked at a bmw dismantlers and just tryed differand wings to see if the lines matched up.
Chris_B86
Wed Feb 27, 2013 9:02 am
Looks a good project, would be nice to see it in action when it's finished.
Demlotcrew
Wed Feb 27, 2013 9:05 am
The front wing insert is a great idea! Looking forward to more updates.
kiwidan
Fri Mar 08, 2013 11:34 pm
started on the bodywork
test fitted the IS front lip and rivited the rear panels on befor i weld them.
cheers
RobbieT
Sat Mar 09, 2013 9:18 am
That's a cool project.
You're gonna get the stance boys seriously hard with that wing mod, i expect a sh*t ton of people trying that (badly) soon! :D
oomz1975
Mon Mar 11, 2013 6:56 pm
kiwidan wrote:they are the standard e30 wings with a section out of a e36 wing welded in.
cheers
MattTheHat325
Sat Mar 16, 2013 8:48 pm
I have actually been thinking of 36 arches for a long time! Looks good mate! :D
retroboyo
Sun Mar 17, 2013 12:39 am
Never seen anyone do that to the front arches before, interesting project
kiwidan
Sun Mar 17, 2013 3:24 am
hopfuly my rear bushes turn up this week .only been waiting 5 weeks for them :x
and also my stud converstion should be here this week.
be like a mini xmas
retroboyo
Sun Mar 17, 2013 8:37 am
kiwidan wrote:hopfuly my rear bushes turn up this week .only been waiting 5 weeks for them :x
be like a mini xmas
and birthday, all rolled into one 8)
kiwidan
Wed Mar 20, 2013 3:10 am
so my wheel stud kit arrived today so much better then the standard bmw bolts
got the front valance and bumper mounts done and also managed to take 10.2kgs out of the front bumper and valance
still waiting for my rear bushes set to turn up
mrrodney
Thu Mar 21, 2013 4:45 pm
like the arches :)
kiwidan
Sun Mar 24, 2013 12:58 am
found the motor im after should be here next month
nice wee 4.0 alloy toyota v8
comes with a 3sge flywheel that can be redrilled but im not to keen on that so ill look for
a light billit one
and also with a 5speed but its a g52 and i dont think they are up to the task so ill be looking for a stronger one
kiwidan
Mon Mar 25, 2013 2:49 am
bushes arrived today now all back on the ground.
can go 40mm lower still in the arse
kiwidan
Wed Mar 27, 2013 5:49 am
so after doing some drilling i managed to get the front including
light grills,kidney grill,bumper and indicators and front panel down to 7.1 kgs.
rix313
Fri Apr 12, 2013 10:50 pm
LHD cage in a RHD car :? I'd look into getting an extra diagonal fitted so there is some protection for your head.
kiwidan
Sat Apr 13, 2013 7:13 am
its all good mate its been built around me and its all up to FAI standards
kiwidan
Sun Apr 14, 2013 10:04 am
the v8 fairy came last night
thats a big bitch
good old 1uz headers
1 x nice factory header
1x WTF factory header
and a quick check (fills the hole)
that is all
kiwidan
Fri Apr 26, 2013 5:33 am
sits better with some weight in it
just got to move it back and make mounts
kiwidan
Wed May 01, 2013 1:52 am
kiwidan
Mon May 06, 2013 6:41 am
modifyed the sump today so the motor will sit right back
appletree
Mon May 06, 2013 10:18 pm
Nice looking project. Thanks for posting the pics, interesting stuff :D
kiwidan
Fri May 10, 2013 4:10 am
my $28.50 remote shifter.
I started by making a spacer block to lift the factory shifter up 10mm and cut and extended the pivot ball
bought a alloy rod and bearing (that's the $28.50) could have used an old ball joint to make it for free.
heres some pics.
now theres about 40mm at the top of the gaer stick between throws.
sweet
Demlotcrew
Fri May 10, 2013 9:07 am
40mm is seriously impressive! But I wonder if you may have trouble with engaging the correct gears in anger :?
kiwidan
Mon Jun 03, 2013 6:13 am
Members
Posted Today, 03:07 PM
found a radiator the size I needed
made a shroud for it and got it all mounted (will cut holes for fans when I have the fans I want)
also made templates for flowing air to radiator (will cut out of alloy this week at work
kiwidan
Mon Jun 03, 2013 6:40 am
sorted the rempte shifter aswell
kiwidan
Tue Jun 04, 2013 7:08 am
bought the alloy home and made it after work
tomislav
Tue Jun 04, 2013 7:30 am
This is a tidy little build, where did you get your front bumper skin from?
kiwidan
Tue Jun 04, 2013 10:56 am
I got the front lower lip from a dude here in nz he makes them .but if you do mean the bumper skin its just a standard outer skin of a fl bimper.
kiwidan
Fri Jun 07, 2013 6:42 am
so this is the new remote shifter I made .
means the whole thing moves with the gearbox aswell.
kiwidan
Wed Jun 12, 2013 5:21 am
air box made
