Will it fit in?
Rich2388
Post Mon Mar 11, 2013 8:27 am
I have got a 2 door 318i. Im buying a new interior at the weekend both front and rear seats and all 4 door cards. I was wondering if anyone would know, will i be able to fit all these in my car to get it home or will i need a van?
Post Mon Mar 11, 2013 8:29 am
Remove your rear seat and passenger front, job jobbed.
Post Mon Mar 11, 2013 8:31 am
wot he said ^
Duke137
Post Mon Mar 11, 2013 8:35 am
pacerpete wrote:Remove your rear seat and passenger front, job jobbed.
His next question will be where does his mrs sit :)
Rich2388
Post Mon Mar 11, 2013 8:39 am
That was what i first thought then i realised i aint got nothing to get front seat out with. The rear seats just pull off n click in and out dont they? So taking the seats out before hand is the only way i will fit it all in?
Post Mon Mar 11, 2013 8:49 am
So how are you going to fit the 'new' interior' if you cannot remove the old one ? :?
Rich2388
Post Mon Mar 11, 2013 8:51 am
Get somone else to do it.
Duke137
:wtf:
Duke137
Post Mon Mar 11, 2013 8:52 am
All you need is a 17mm socket and a ratchet
suedenim
take the rear bench out and replace with new. If you're not too tall, turn new fronts upside down and sit seat backs into rear footwells, rest of the crap will fit into boot.
1982 E21 316 Baltic Blau
1989 318i 2 Door Sterling Silber
Feedback: http://www.e30zone.net/modules.php?name ... highlight=
Post Mon Mar 11, 2013 8:54 am
This could end badly. We need pics ! :)
Rich2388
Post Mon Mar 11, 2013 9:11 am
pacerpete wrote:This could end badly. We need pics ! :)
Oh i dont like the sound of this. Glad i asked now. What is it you need pics of pete?
Post Mon Mar 11, 2013 9:18 am
Your mrs would be a good start :)
Sanchez
Post Mon Mar 11, 2013 9:48 am
Another victim Pete.
Mo13
Post Mon Mar 11, 2013 9:50 am
:rolling:
Post Mon Mar 11, 2013 9:53 am
Rich2388 wrote:I have got a 2 door 318i. ............... all 4 door cards.
polsta
Post Mon Mar 11, 2013 9:55 am
:D I Second this
Post Mon Mar 11, 2013 9:57 am
the top half of the rear seat has a bracket on either side at the bottom secured with a bolt this is hidden by a bit of overlapping rear quarter card material.you will need a 10mm spanner for this unless they have already been removed and not put back in which is often the case .
BATTS91
Post Mon Mar 11, 2013 11:56 am
Owning an E30 and not having a socket set is a bad combo.
andyp
True Old Skooler
Post Mon Mar 11, 2013 12:00 pm
seats will fit, door panels will NOT fit
kangman
Post Mon Mar 11, 2013 12:17 pm
its very simple mate,
have the two socket sizes mentioned above and a flat screwdriver or a spreading knife if your limited on tools
Fronts
use a screw driver/ spreading knife to take off the black caps that cover the nuts on the front seat runners. Then you shall see 4 nuts, you undo them and then lift the seat up and its out :D
Rears
Take the rear seat base out by giving it a tug, then there should be a bolt on each side to take out the back rest which you undo and then lift the back rest up and then towards you.
No need to take it to a garage as its too easy of a job, can be done under 20mins
Rich2388
Post Mon Mar 11, 2013 12:26 pm
BATTS91 wrote:Owning an E30 and not having a socket set is a bad combo.
Haha your probarly right there mate. But on the other hand whats the point in me having a socket set if i wouldnt know what do with it lol. Id have it and anything that goes wrong i wouldnt know how to fix anyway.
Cheers kangaman. The way you have made it sound so easy i think even i might just about be able to the seats lol. Just what i needed cheers. Hiw difficult are the front door cards and rear quarter panels?
polsta
Post Mon Mar 11, 2013 12:38 pm
spreading knife 8O :D
rich,k go buy one of these and keep it in the boot, its only small and includes everything for general e30 tinkering and all interior stuff and exterior trim, best most used tool kit ive ever bought !
http://www.halfords.com/webapp/wcs/stor ... yId_255215
polsta
Post Mon Mar 11, 2013 12:40 pm
door cards are very easy, the sooner you start tinkering the better and more familar you will become, you could easily do it blind without knowing and just finding as you go
a small trim removal tool bar is handy, about £3 to buy
Rich2388
Post Mon Mar 11, 2013 12:44 pm
polsta wrote:spreading knife 8O :D
Cheers polsta. Aint that expensive either. Im going to pick one of those up at the weekend
polsta
Post Mon Mar 11, 2013 12:49 pm
no worries, its well worth having and very handy, half price too is a bargain, i might even go get another one to keep in my garage
