the blower doesnt work on settings 1 and 3 and is intermitant on 2. also sometimes it seems to lose power and blows alot slower than it should then picks up again so i'm guessing theres a loose or dirty conection somewhere?
cheers in advance
i tried the switch and thats fine, and bridged the connection but the same problem existsBrianmoooore wrote:Wiring also goes through a white 6 or 8 pin plug and socket located around the top left of the heater assembly. Sort of straight back from the clock.
