Will it fit?
Martin323i
Post Thu Dec 29, 2005 10:40 am
Hi
I found a Torque Converter from and old 528i. Connected to a 4hp22 - the same as my box.
Will this fit on my 323i 4hp22? Will it be neccessary to change the flywheel over? Is it physically too large to fit in the bellhousing?
Martin
Demlotcrew
Post Thu Dec 29, 2005 10:56 am
The ETK say no!
Andrew
Martin323i
Post Thu Dec 29, 2005 11:03 am
damn.
Well, back to searching then.
Post Thu Dec 29, 2005 2:36 pm
Can't always go by the ETK (unless it gives dimensions).
The slightest change in spec or design will result in a different part number.
Martin323i
Post Thu Dec 29, 2005 7:31 pm
Argos wrote:What's wrong with yours anyway?? Don't tell me, the tinny rattle just off idle and the loss of the 56mph lock up??
Yup, Lockup clutch engaging whenever it wants to or doesn't when it should. Started with the rattle just off idle but has now turned into a loud scraping noise all the time while in drive and reverse. I think the lockup clutch probably engaged permanently - even if not completely - causing the noise.
Oi
