Best source for shouldered wheel studs?
winx
Post Mon Jan 28, 2013 12:51 pm
I bought a set of wheel studs from Rallydesign ages ago but have now decided I would like to fit proper shouldered ones.
Is there anywhere else apart from Demon Tweeks to buy these from?
Post Mon Jan 28, 2013 1:32 pm
Mine came from the States Henry, will try to find a link
Post Mon Jan 28, 2013 1:37 pm
Demlotcrew
Post Mon Jan 28, 2013 11:02 pm
Ha! I know speed shack, many days were spent offloading alloys from west Drayton scrap yard while I should have been at class!
AdamGardner
Post Tue Jan 29, 2013 12:48 am
turner motorsports do some nice ones that i have seen. never too sure about usa import tax being an issue??
Kos
Post Tue Jan 29, 2013 12:57 am
Demlotcrew wrote:Ha! I know speed shack, its near pete's where i spent many days unloading inside him when I should have been at class!
winx
Post Tue Jan 29, 2013 7:39 am
Thanks guys.
Turner Motorsport seem to be the best at the moment with the bullet shape.
Any other suggestions before I order? (cheaper possible?!)
Post Tue Jan 29, 2013 9:09 am
I got mine from this guy, came to about £80 all in IIRC http://www.s14.net/forums/showthread.ph ... rsion-kits
winx
Post Tue Jan 29, 2013 9:36 am
Perfect thanks for that Dan, looks just the ticket. I take it 75mm bullet nose is the best option? Currently running standard 15" BBS but may look to go for something else that requires a spacer in the future. 90mm would obviously cover all bases but seems overkill if I am never going to use them!
MillRat
Post Fri Feb 01, 2013 4:57 pm
I use the 90mm Turner studs on my race car. They are great, but I needed to buy an extra long socket to engage to wheel nut when fully torqued. This in itself is not a major issue, it might just be inconvenient should I ever "mis-place" this socket.
Remember.. cheaper is rarely better.. and when you are talking about wheel studs (pretty important items), cheaper is probably never better.
EDIT: Here is a picture of them fitted (showing how long the 90mm studs are with a spacer).
Cheers,
Michael.
winx
Post Thu Feb 14, 2013 1:01 pm
Thanks guys, my new studs arrived this morning from Dan's link. They are TUV approved so quite happy that they are fit for purpose.
I guess I just screw them in using 2 nuts with locktite to the standard wheelnut torque?
Kos
Post Thu Feb 14, 2013 1:41 pm
I just clocked your mug in one of the classic car mags with Mr Bean :D
winx
Post Thu Feb 14, 2013 1:47 pm
yup, that repair kept me busy for a year!
Kos
Post Thu Feb 14, 2013 2:23 pm
Question is, is it on the register lol
winx
Post Fri Feb 15, 2013 10:30 pm
Nope, not even close to being a write off!
Post Fri Feb 15, 2013 10:54 pm
winx wrote:Thanks guys, my new studs arrived this morning from Dan's link. They are TUV approved so quite happy that they are fit for purpose.
Use a 5.5mm (IIRC) hex key to screw them in, make sure you clean the hub threads out with brake cleaner and a tap before fitting or the loctite will not work properly 8)
Demlotcrew
Post Mon Feb 18, 2013 11:24 am
Im surprised you have gone for the ones TheDan posted up, most manufacturers have moved on to a fine pitch fastener, including BMW!
Im sure they will work fine.
winx
Post Mon Feb 18, 2013 11:43 am
The wheel bolts never came loose before on track so I can't see that these will, hence purchase!
If I was interested in telling people how my finer pitch thread is better than their standard thread then I would have course bought the 1.25 pitch or whatever the latest trend is :wink:
Demlotcrew
Post Mon Feb 18, 2013 12:26 pm
Just seems like a missed opportunity to upgrade to something better. :)
Post Mon Feb 18, 2013 2:15 pm
Better than standard, where there is not a problem anyway? :mad:
redcar
Post Mon Feb 18, 2013 8:05 pm
Demlotcrew wrote:Im surprised you have gone for the ones TheDan posted up, most manufacturers have moved on to a fine pitch fastener, including BMW!
hmm, should have used a Nissan!
Demlotcrew
Post Tue Feb 19, 2013 2:51 pm
8)
