Best source for shouldered wheel studs?
winx
I bought a set of wheel studs from Rallydesign ages ago but have now decided I would like to fit proper shouldered ones.
Is there anywhere else apart from Demon Tweeks to buy these from?
Mine came from the States Henry, will try to find a link
Demlotcrew
Ha! I know speed shack, many days were spent offloading alloys from west Drayton scrap yard while I should have been at class!
AdamGardner
turner motorsports do some nice ones that i have seen. never too sure about usa import tax being an issue??
Kos
Demlotcrew wrote:Ha! I know speed shack, its near pete's where i spent many days unloading inside him when I should have been at class!
winx
Thanks guys.
Turner Motorsport seem to be the best at the moment with the bullet shape.
Any other suggestions before I order? (cheaper possible?!)
I got mine from this guy, came to about £80 all in IIRC http://www.s14.net/forums/showthread.ph ... rsion-kits
winx
Perfect thanks for that Dan, looks just the ticket. I take it 75mm bullet nose is the best option? Currently running standard 15" BBS but may look to go for something else that requires a spacer in the future. 90mm would obviously cover all bases but seems overkill if I am never going to use them!
MillRat
I use the 90mm Turner studs on my race car. They are great, but I needed to buy an extra long socket to engage to wheel nut when fully torqued. This in itself is not a major issue, it might just be inconvenient should I ever "mis-place" this socket.
Remember.. cheaper is rarely better.. and when you are talking about wheel studs (pretty important items), cheaper is probably never better.
EDIT: Here is a picture of them fitted (showing how long the 90mm studs are with a spacer).
Cheers,
Michael.
winx
Thanks guys, my new studs arrived this morning from Dan's link. They are TUV approved so quite happy that they are fit for purpose.
I guess I just screw them in using 2 nuts with locktite to the standard wheelnut torque?
Kos
I just clocked your mug in one of the classic car mags with Mr Bean
winx
yup, that repair kept me busy for a year!
Kos
Question is, is it on the register lol
winx
Nope, not even close to being a write off!
Use a 5.5mm (IIRC) hex key to screw them in, make sure you clean the hub threads out with brake cleaner and a tap before fitting or the loctite will not work properlywinx wrote:Thanks guys, my new studs arrived this morning from Dan's link. They are TUV approved so quite happy that they are fit for purpose.
Demlotcrew
Im surprised you have gone for the ones TheDan posted up, most manufacturers have moved on to a fine pitch fastener, including BMW!
Im sure they will work fine.
winx
The wheel bolts never came loose before on track so I can't see that these will, hence purchase!
If I was interested in telling people how my finer pitch thread is better than their standard thread then I would have course bought the 1.25 pitch or whatever the latest trend is
Demlotcrew
Just seems like a missed opportunity to upgrade to something better.
Better than standard, where there is not a problem anyway?
redcar
hmm, should have used a Nissan!Demlotcrew wrote:Im surprised you have gone for the ones TheDan posted up, most manufacturers have moved on to a fine pitch fastener, including BMW!
Demlotcrew
