M3 REV COUNTER STOPPED WORKIN....?
Cov
JUST WONDERING IF ANYONE COULD TELL WHERE THE PICK UP FOR THE REV COUNTER IS ON MY M3 EVOII, JUST DIDN'T WORK THIS MORNING WHEN I STARTED IT, ANY HELP WOULD BR GREAT THANKS.
karlp
works off the ecu.
Karl
Karl
Demlotcrew
Are you sure?karlp wrote:works off the ecu.
Karl
Andrew
karlp
To be precise.
An engine speed sensor on the bellhousing feeds a signal to the ECU - the ECU then sends a signal to the rev counter.
Karl
Karl
Demlotcrew
Yup thats correct, but there is no direct feed from the ECU which you can see if one were to take a look at the ECU.
Andrew
Andrew
karlp
On my diagrams pin 21 from the ecu goes to tachometer and fuel economy gauge.
karl
karl
herman
Could be re-chargeble cell in the cluster
Poor connection at pin 9 (black wire) of the C101 connector is often the cause of no tacho on an E30.
Don't have any M3 diagrams handy, but would expect this to be the same on a M3.
jpboost
Brian,
Is the C101 connector the ECU end or the clock end?
About half way between. It's the twenty something pin plug and socket clipped to the engine bulkhead just inboard of the fusebox, where the engine loom connects to the body looms.jpboost wrote:Brian,
I'm assuming that the M3 is similar to other E30s in this area.
Demlotcrew
Yup its the same, but it has a few extra feeds.
Andrew
Andrew
jpboost
cheers.
my tacho hasn't worked since I got the car, keep meanign to get around to do some investigating. at least I now know where to start.
thanks again
thanks again
toptints
howdy. My rev counter stopped working on my 325i and it turned out to be a short circuit in the boot which was down to the boot light. Every time i used to open my boot it used to blow a fuse, which runns the same circuit as the rev counter, so check your fuses. If it is blown, it could be down to a short circuit on one of your lights.. ie: glove box, interior or boot etc.. A BMW specialist in Gloucester found the fault on mine. Good Luck.
Cov
THANKS A MILLION LADS SHOULD BE ABLE TO GET IT SORTED FROM ALL YOUR INFO, THANKS AGAIN.
Dan318-is
the renowned fuse 21toptints wrote:howdy. My rev counter stopped working on my 325i and it turned out to be a short circuit in the boot which was down to the boot light. Every time i used to open my boot it used to blow a fuse, which runns the same circuit as the rev counter, so check your fuses. If it is blown, it could be down to a short circuit on one of your lights.. ie: glove box, interior or boot etc.. A BMW specialist in Gloucester found the fault on mine. Good Luck.
bastad thing!
