M3 REV COUNTER STOPPED WORKIN....?
Demlotcrew
Are you sure?karlp wrote:works off the ecu.
Karl
Andrew
Demlotcrew
Yup thats correct, but there is no direct feed from the ECU which you can see if one were to take a look at the ECU.
Andrew
Andrew
Could be re-chargeble cell in the cluster
- Brianmoooore
Poor connection at pin 9 (black wire) of the C101 connector is often the cause of no tacho on an E30.
Don't have any M3 diagrams handy, but would expect this to be the same on a M3.
- Brianmoooore
About half way between. It's the twenty something pin plug and socket clipped to the engine bulkhead just inboard of the fusebox, where the engine loom connects to the body looms.jpboost wrote:Brian,
Is the C101 connector the ECU end or the clock end?
I'm assuming that the M3 is similar to other E30s in this area.
Demlotcrew
Yup its the same, but it has a few extra feeds.
Andrew
Andrew
howdy. My rev counter stopped working on my 325i and it turned out to be a short circuit in the boot which was down to the boot light. Every time i used to open my boot it used to blow a fuse, which runns the same circuit as the rev counter, so check your fuses. If it is blown, it could be down to a short circuit on one of your lights.. ie: glove box, interior or boot etc.. A BMW specialist in Gloucester found the fault on mine. Good Luck.
Dan318-is
the renowned fuse 21toptints wrote:howdy. My rev counter stopped working on my 325i and it turned out to be a short circuit in the boot which was down to the boot light. Every time i used to open my boot it used to blow a fuse, which runns the same circuit as the rev counter, so check your fuses. If it is blown, it could be down to a short circuit on one of your lights.. ie: glove box, interior or boot etc.. A BMW specialist in Gloucester found the fault on mine. Good Luck.
bastad thing!
