engine mounts
cjdonny
Post Sun Feb 10, 2013 2:06 pm
Do these cause vibrations
Or what else can cause this
If there the same ones on the car from new?
Thinking of changing mine (rubber )
How easy are they to do
CHEERS
Post Sun Feb 10, 2013 2:54 pm
Easy to do
If its an M20 engine you can use Ford RS/Capri mounts from Burton Power
http://www.burtonpower.com/engine-mount ... fp292.html
I've used these as have other zoners - seem to work well and significantly cheaper than from the dealers
cjdonny
Post Sun Feb 10, 2013 3:18 pm
cheers sorry should have said :roll:
m42 engine
318 IS
cjdonny
Post Tue Feb 12, 2013 12:35 pm
Is there a guide to changing these?
318 IS
Grrrmachine
E30 Zone Wiki / Team Member
Post Tue Feb 12, 2013 12:49 pm
GUIDE:
Undo nuts
Lift engine
Remove mounts
Fit new mounts
Lower engine
Tighten nuts.
cjdonny
Post Tue Feb 12, 2013 1:27 pm
318 IS
Post Tue Feb 12, 2013 1:39 pm
Grrrmachine wrote:GUIDE:
Undo nuts
Lift engine
Remove mounts
Fit new mounts
Lower engine
Tighten nuts.
Couple of points to note: If you're going to support the engine from underneath, on a jack, use a large piece of wood between jack and sump, large enough to cover the entire sump pan.
The holes in the alloy engine mounts are shaped to allow the mounts to be twisted sideways.
An alternative to lifting the engine right up is to unbolt the alloy arm from the block.
cjdonny
Post Tue Feb 12, 2013 1:49 pm
318 IS
cjdonny
Post Wed Mar 06, 2013 4:55 pm
On with this now
How far can I jack the engine?
Don't want to damage anything
318 IS
cjdonny
Post Wed Mar 06, 2013 8:11 pm
well got them off but the E36 mounts dont fit :( look the same apart from the locating stud is futher apart
GSF told me these were the correct type :twisted:
318 IS
cjdonny
Post Wed Mar 06, 2013 8:12 pm
318 IS
Rtaylor2208
Post Thu Mar 07, 2013 12:07 am
Take them back and order the ones Capri-Rob linked to above.
cjdonny
Post Thu Mar 07, 2013 12:18 am
i thought they were for the m20 :?
318 IS
cjdonny
Post Thu Mar 07, 2013 1:41 pm
£122 plus postage from bmw parts online :'(
318 IS
Rtaylor2208
Post Thu Mar 07, 2013 2:18 pm
Ah sorry, I didn't see the M42 bit. Have you tried asking Meatballs82 to help get you a part number from ECP for the correct ones.
capnmchl
Post Thu Mar 07, 2013 7:04 pm
I know CP4L sell q-drive M10 engine mounts. Looking at pictures, these appear to look the same.
Maybe someone can confirm if M10 and M40 mounts are the same?
