320 m20 engine esitates on power
gcmog
Post Thu Feb 07, 2013 10:26 pm
Hi can anybody help with a problem i have with my 1988 320i.Intermittant lack of power , holding itself back & slight misfire. I have fitted new plugs & leads , new coil ,new intake hoses , removed & had the injectors checked, new inlet manifold gaskets & fuel hoses. I have had the fuel pump out of the tank & all seems ok. Getting a bit fed up now, can anybody help . :mad:
Quaser
Post Thu Feb 07, 2013 10:35 pm
timing?
does it happen when its cold/hot - could be the blue or brown temp sensors
could also be crankshaft sensor
Post Thu Feb 07, 2013 10:37 pm
Have you checked the distributor cap and rotor arm?
Also worth changing the fuel filter, if it hasn't been done in yonks, as a clogged one will be restricting the fuel flow.
How many miles has it done? Could be worth carrying out a compression test to ensure all six pots are reading roughly equal pressures.
Grrrmachine
E30 Zone Wiki / Team Member
Post Fri Feb 08, 2013 6:34 am
Is this all the way through the rev range, or just at lower revs?
mcbonio
Post Fri Feb 08, 2013 9:08 am
Sounds like an ignition issue, check dizzy cap and rotor arm.
Grrrmachine
Post Fri Feb 08, 2013 10:57 am
Also, if your "new" leads were aftermarket ones consider switching back to the originals. General consensus is that non-BMW leads aren't good enough in the long term,
gcmog
Post Sat Feb 09, 2013 9:39 pm
Hi all, thanks for your replies .The rotor arm & dizzy are good , but it does feel more like fuel starvation , it is at its worst below 2000rpm but still feels like it is holding back all the way the rev range. I put a new in-line filter in it a couple of months ago.I removed the fuel pump out of the tank again today & checked ,seems ok & pumps what looks like ample fuel & holds pressure in the system.I have re-checked the timing & thats ok.The poor old girl is trying my patience slowly , because the fault isn't always there , or disappears if you stop & re-start some times.She has done 189000 now , but has been a reliable motor for the past 14 years.It has also developed a little hicup on tick over.All suggestions will be well appreciated.cheers
Post Sat Feb 09, 2013 9:42 pm
I would suggest a compression test as the next step - all six cylinders should be giving roughly equal readings of 170 psi or more.
gcmog
Post Sun Feb 10, 2013 9:35 pm
yeh , thanks for the suggestion , i'll get it sorted this week & let you know the outcome. cheers.
