320 m20 engine esitates on power
gcmog
Hi can anybody help with a problem i have with my 1988 320i.Intermittant lack of power , holding itself back & slight misfire. I have fitted new plugs & leads , new coil ,new intake hoses , removed & had the injectors checked, new inlet manifold gaskets & fuel hoses. I have had the fuel pump out of the tank & all seems ok. Getting a bit fed up now, can anybody help .
Quaser
timing?
does it happen when its cold/hot - could be the blue or brown temp sensors
could also be crankshaft sensor
Have you checked the distributor cap and rotor arm?
Also worth changing the fuel filter, if it hasn't been done in yonks, as a clogged one will be restricting the fuel flow.
How many miles has it done? Could be worth carrying out a compression test to ensure all six pots are reading roughly equal pressures.
Grrrmachine
- E30 Zone Wiki / Team Member
Is this all the way through the rev range, or just at lower revs?
mcbonio
Sounds like an ignition issue, check dizzy cap and rotor arm.
Grrrmachine
Also, if your "new" leads were aftermarket ones consider switching back to the originals. General consensus is that non-BMW leads aren't good enough in the long term,
gcmog
Hi all, thanks for your replies .The rotor arm & dizzy are good , but it does feel more like fuel starvation , it is at its worst below 2000rpm but still feels like it is holding back all the way the rev range. I put a new in-line filter in it a couple of months ago.I removed the fuel pump out of the tank again today & checked ,seems ok & pumps what looks like ample fuel & holds pressure in the system.I have re-checked the timing & thats ok.The poor old girl is trying my patience slowly , because the fault isn't always there , or disappears if you stop & re-start some times.She has done 189000 now , but has been a reliable motor for the past 14 years.It has also developed a little hicup on tick over.All suggestions will be well appreciated.cheers
I would suggest a compression test as the next step - all six cylinders should be giving roughly equal readings of 170 psi or more.
gcmog
yeh , thanks for the suggestion , i'll get it sorted this week & let you know the outcome. cheers.
