Headlight wiper removal HELP!!
beemerbird
Post Fri Feb 01, 2013 2:47 pm
I need to remove one of my headlight wipers so that I can remove the grille to replace a one way valve.
I've removed the tiny nut at the end of the wipers, sprayed on a load of WD40, been questioned by the plod about what I'm doing 8O and can't shift the wipers.
Am I missing something obvious???
Help!
Fi :D
Post Fri Feb 01, 2013 2:52 pm
They are on a splined rod, and will pull off though you may have to yank at it a bit.
beemerbird
Post Fri Feb 01, 2013 2:56 pm
Cheers, Maurice. i'll give it another go once the WD has sunk in and the plod have gone :P
Post Fri Feb 01, 2013 2:59 pm
Essex plod are meanies, and gave me 9 points on my licence when I had my first E30, back in the early '90s. I had to sell it and revert to my Minor Traveller. :(
beemerbird
Post Fri Feb 01, 2013 3:00 pm
beemerbird
Post Fri Feb 01, 2013 3:38 pm
Success! How someone can be so pleased to have working windscreen washers is beyond me :D :D :D :D
Post Fri Feb 01, 2013 5:00 pm
Well done. :) They can be a right pain, those little valves in the E30's washer system.
