e30-EVN
Sun Jan 27, 2013 6:36 pm
Turned the key, scowled at it as nothing happened, came back inside
LOL :)
SHAKEELE30
Boost Junkie
Sun Jan 27, 2013 6:50 pm
changed front shocks over for some bilsteins, and the springs, and then tried to take the disks off, but end up rounded off the f'in small screw that holds them in, on both sides, that just wound me right up...
ajay
Sun Jan 27, 2013 6:52 pm
Finally got a chance to re fit the rear brakes, removed them last summer and slowly refurbed/rebuilt them as new. With a bit of luck the fronts will be on too, soon.
bigwinn
Sun Jan 27, 2013 6:53 pm
did the red/black wire mod and fixed my CL issue
:o:
Bronzit gone- she lives on
'89 325i auto touring: Malachite Green
Now, I'm no gynecologist, but I know a tw4t when I see one...
BHadley
Sun Jan 27, 2013 11:29 pm
Got the dash cluster lighting up, now to sort the headlight fog light and headlight adjuster display bulbs.
kieran325
Mon Jan 28, 2013 12:40 am
Washed the M3 and wheeled it back in the garage.
Sanchez
Mon Jan 28, 2013 1:03 am
bss325i wrote:
Simon13 wrote:
Sanchez wrote:made it run on 6 cylinders :D
The problem was?!
+1?
Thought it was fixed but must be dodgy wiring somewhere as its intermittent now.
Might get the inlet off and injectors away for cleaning.
Mon Jan 28, 2013 12:26 pm
Bought these over the weekend :D
Don't worry, there are 4 of them.
verde
Mon Jan 28, 2013 1:41 pm
Rav335uk wrote:Bought these over the weekend :D
Thought they were keskins at first, i was about to erupt haha
Raise hell praise Dale.
cakey87
Mon Jan 28, 2013 1:50 pm
Put 5 litres of water in it instead of petrol, surprisingly it dusnt want to start.
FinalD
Mon Jan 28, 2013 3:15 pm
cakey87 wrote:Put 5 litres of water in it instead of petrol, surprisingly it dusnt want to start.
e30ftw
Mon Jan 28, 2013 5:16 pm
hennared323i
Mon Jan 28, 2013 5:26 pm
I opened the garage door, looked at the turd, then closed the door again
spook
League two here we come !!!
Fri Feb 01, 2013 5:20 pm
Taxed the coont, up early tomorrow for a blast :cool:
Jos
Fri Feb 01, 2013 5:45 pm
Connected jump lead between solenoid and batt -ve. Starter still not turning, locked it again and went inside to find other starter motor.. Sunday I swear I will change it this time.
'94 e36 tree climber
Quaser
Fri Feb 01, 2013 5:56 pm
its ok - ive done that in the past (to be fair the engine was over heating and my mate put water in a fuel can and let the car run out of fuel too!)
Quaser
Fri Feb 01, 2013 5:57 pm
Fitted to the exhaust on the m52 - car is overfuelling :(
removed kinks from power steering lines and still not working :(
FinalD
Fri Feb 01, 2013 7:32 pm
Fitted my tidied up grills...
I'll do a write up on what I've done later. :)
BEERBOY123
Fri Feb 01, 2013 9:24 pm
Wished it goodnight while I was boosting the boiler in the garage.
Two headblenders, couple of bags of MC Hammer, 5 litres of FFF, a 48ft bastard, a box of jumped-up custard and some soggy chimps
FinalD
Sat Feb 02, 2013 12:12 pm
Drove it to the MOT, drove it home again...now I need to fix some stuff within 10 working days. :D
gooner1
Out humping Reindeer
Sat Feb 02, 2013 12:27 pm
Removed the remains of the old water pump, along with the 4 correct length mounting bolts instead of the laughably short bolts that had no chance of connecting the pump to the block :x , fitted new belts. Filled with new coolant , bled the system.
No leaks, no over heating and a lovely warm interior. :D
BATTS91
Sat Feb 02, 2013 4:01 pm
Today i hung the arse out irresponsably and got waved by little kids because of it .
Pacer take notes it may help ! Lol :D
mcbonio
Sat Feb 02, 2013 4:23 pm
FinalD wrote:Drove it to the MOT, drove it home again...now I need to fix some stuff within 10 working days. :D
Oh dear, whats up with it FinalD?
Gert_8
Sat Feb 02, 2013 4:39 pm
Hahahahah aha!! Love it :D
HJG-E30
Sat Feb 02, 2013 5:50 pm
removed rear calipers. Brake pad in o/s disintegrated upon removal 8O
Motorhole
Sat Feb 02, 2013 7:08 pm
Finally got round to sorting out pedal box plumbing after a headache with wrong size bulkhead fittings. Just got to do the t-piece to left/right front lines and the in-car pedal box-rear t-piece line now :)
Sanchez
Sun Feb 03, 2013 2:01 pm
Tidied up under my rear end a bit and fitted my LSD.
polsta
Sun Feb 03, 2013 2:32 pm
sorted through this lot, counted bagged it all in bigger bags for the sections of car the bits are for, took ages
bab-91
Sun Feb 03, 2013 4:11 pm
polsta wrote:sorted through this lot, counted bagged it all in bigger bags for the sections of car the bits are for, took ages
I see your collection and will raise you on Friday :tongue:
polsta
Sun Feb 03, 2013 4:16 pm
:D thats only the fittings mate, but will be super to re build it with nice new fittings on everything, cant wait to get cracking
also got the bonnet foam but forgot to bring it home
still a few more things to get to add to the bounty stash ive alrewady got tucked away :cool:
FinalD
Sun Feb 03, 2013 4:38 pm
Not too much really, I expected it to fail really badly for it's first MOT with me. Pleasantly surprised though that it failed on the following:
Nearside Front bleedniple Braking system leaking (3.6.A.1) **DANGEROUS**
Rear into tank Fuel hose leaking (7.2.3) **DANGEROUS**
Exhaust emissions carbon monoxide content excessive (7.3.B.2a)
Parking brake efficiency below requirements (3.7.A.10) **DANGEROUS**
I'll sort it all over the next week.
The bleed nipple isn't the bleed nipple but is the union between the solid copper line and the new braided line, it has a very minor weep, but obviously I need to sort that.
Fuel hose...I'm not sure which hose/pipe they mean so will have to have a play underneath.
Emissions were hilarious (pre cat car so max of 3.5% CO), it ran 6.78%. :D I think this is mostly due to the air sensor and ECU being different from what came with the engine, I'll swap them over and also have a check/adjust with the TPS etc. Helpfully, the guys at the garage are happy for me to (provided I know how to adjust stuff...to the wiki!) run the car on their ramps whilst metering the CO until it is within tolerance then they'll retest it. 8)
The hand brake, I had made it too tight before so slackened it off, too far it seems, easy fix.
Not too bad as the car hadn't been MOTed since March 2010 and had blown an engine in late 2010, early 2011. Over the past 6 months I've stripped large amounts down and rebuilt them and sourced a replacement engine.
Also as it was the first proper drive I've done in the car...wow, handles a lot better than I'd expected and makes a glorious noise. I drove home with the roof down and I love it. :D
Gert_8 wrote:Hahahahah aha!! Love it :D
:D One of my fav gifs
beemerbird
Sun Feb 03, 2013 5:06 pm
I admired it today. Yesterday I fixed a lingering wash / wipe problem, then took it for a celebratory hand wash :D
Bristol_Jer
Sun Feb 03, 2013 5:25 pm
I took off the exhaust, heatshield and prop ready to take the gearbox off this afternoon and tried not to look at the rust bubbling through the rear wheel arches! :cry:
gjj107
Sun Feb 03, 2013 8:15 pm
Patched the front footwell, and had the windscreen in and out to try and stop the leak.
And then had poke in the rear inner arches and found small holes both sides so more welding fast approaching methinks
Gert_8
Sun Feb 03, 2013 8:21 pm
I squeezed past it getting to mt toolbox, then squeezed back and adjusted the sheet covering the bonnet. :D
