Good carkeeping
318isPMK
Post Fri Jan 25, 2013 10:47 pm
Hello I have the carpets out... any tips for products, Utensils and proceedure when it comes to cleaning the bugger.
Drip dry or find someway to accelerate the drying? (shrinkage is my worry there).
As ever
Cheers in advance :)
Paul
Post Fri Jan 25, 2013 10:57 pm
Pressure washer is the best way to clean the carpet, helped with detergent and a stiff brush.
It won't shrink or deform in any way, what ever you do to it.
Best way I've found to dry them is to hang them up diagonally on edge. Most of the water will quickly drain to the lowest corner, where you can repeatedly squeeze it out.
Post Fri Jan 25, 2013 10:58 pm
Anymore rust pics ? :)
318isPMK
Post Fri Jan 25, 2013 11:02 pm
Its with Boyd the now for Welding.
There was a patch under the pedals that was letting in water. Despite being told it was related to fluid from a replaced part... I cant mind which.
It turned out a previous owner... I think THE previous owner taped up a hole in the boot and I mean taped, then resprayed it. Ive always felt uncomfortable taking a screwdriver to a car I dont own but never again will I buy one I havent poked!
Lol
318isPMK
Thanks Brian
snakebrain
+1 on the pressure washer. Hang it vertically against a wall or something. AG Interior shampoo sprayed on, brushed in to loosen the grime, pressure wash off, repeat until mostly clean water comes off it. (Expect that to take a while..)
ajay
Post Fri Jan 25, 2013 11:08 pm
If you can, run a wet n dry vacum over it. Helps aid the drying procedure and sucks up ingrained dirt too.
318isPMK
Post Fri Jan 25, 2013 11:11 pm
Dont have one but Im sure facebook will turn one up
polsta
Post Fri Jan 25, 2013 11:27 pm
Would the pressure wash method be better than getting a mobile Valerie type person to do a proper clean on the carpets and seats whilst out ? Was thinking of getting someone to do the lot and boot carpets too
verde
Post Fri Jan 25, 2013 11:28 pm
I was going to rent a carpet cleaner and do mine...will this work or is it pointless. We left our pressure washer in edinburgh when we moved :/
Raise hell praise Dale.
bab-91
Post Fri Jan 25, 2013 11:40 pm
My carpets would disintegrate if I pressure washed them...
Crusty ... :(
318isPMK
Post Fri Jan 25, 2013 11:44 pm
My carpets seem decent and my seats are nice so I'll do a before after stylee
Post Fri Jan 25, 2013 11:48 pm
pacerpete wrote:Anymore rust pics ? :)
Gavla
Post Sat Jan 26, 2013 11:12 am
polsta wrote:Would the pressure wash method be better than getting a mobile Valerie type person to do a proper clean...
Yes
polsta wrote:...on the carpets and seats whilst out ? Was thinking of getting someone to do the lot and boot carpets too
I would get the valet to do the seats / headlining properly.
snakebrain
Post Sat Jan 26, 2013 2:27 pm
bab-91 wrote:My carpets would disintegrate if I pressure washed them...
Crusty ... :(
All the more reason to do it! You'll be amazed how much of that 'used car smell' comes from the carpets.
(P.S. Not calling your car a smelly turd or anything! :D )
bab-91
Post Sat Jan 26, 2013 7:16 pm
Crusty ... :(
It's more musty than smelly! I'll add it to my to-do-list! :(
verde
Post Sat Jan 26, 2013 7:17 pm
Im kinda scared to wash mine incase the " E30 smell " goes away
Post Sat Jan 26, 2013 7:57 pm
Crusty ... :(
The only E30 carpet that I've had disintegrate, is one in a touring that had literally been under 2 - 3 inches of water for over two years. A damaged rear hatch had been left ajar, allowing water in to fill whatever it could. Wheel well and boot pockets filled to the top, and the floor pan up to the top of the panels sealing the inside of the sills.
Was an interesting 100 mile drive home with waves lapping around my feet, and a deluge from the back every time the brakes were used.
Carpet and seats were scrap, but the metal of the boot and floor pan were immaculate.
bab-91
Post Sat Jan 26, 2013 8:11 pm
Brianmoooore wrote: The only E30 carpet that I've had disintegrate, is one in a touring that had literally been under 2 - 3 inches of water for over two years. A damaged rear hatch had been left ajar, allowing water in to fill whatever it could. Wheel well and boot pockets filled to the top, and the floor pan up to the top of the panels sealing the inside of the sills.
Sounds like an interesting drive home :snigger: but mine couldn't be that bad! 8O
What kept the floor from rusting!? I would have imagined it would have caused serious rot!
but it was rather brittle and ripped very easily when taking it out and I did the job right.. took out the heater matrix! :x seemed to rip under its own weight!
Is the aqua touring still alive?
Topblag
Post Sat Jan 26, 2013 8:14 pm
I brushed in some TFR after the first jet wash, then jetwashed again until the water running out of it was clear. Hung up on a ladder then left to drip dry.
I favour using the car with the carpet out, or at least leave it sitting out in the rain with the carpet out to make sure there are no leaks, as they can be hard to spot under a thick foam backed carpet with overmats.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Post Sat Jan 26, 2013 8:19 pm
It's the green one in my sig.
jimbom30cab
Tech 1 freak
Post Sat Jan 26, 2013 8:43 pm
For my carpet I used a couple of cans of that foam cleaner vanish. Then scrub scrub scrub and wash off. My carpet came up like new and I mean absolutely spotless and perfect.
bab-91
Post Sat Jan 26, 2013 8:50 pm
We found the secret to keeping a e30 rust free ... submerge it in water winkeye
polsta
Post Sat Jan 26, 2013 9:00 pm
jimbom30cab wrote:For my carpet I used a couple of cans of that foam cleaner vanish. Then scrub scrub scrub and wash off. My carpet came up like new and I mean absolutely spotless and perfect.
decent stuff that is, thats what i use to keep them clean, but she needs a good wet type of wash 1st
ajay
Post Sat Jan 26, 2013 9:35 pm
Beware using vanish on your seats/door cards, houndstooth will run the darker colour!
318isPMK
Post Sun Jan 27, 2013 5:13 pm
carpets karchered 2 hours worth.... still freezing! they were allready covered in soap which was weird. ill check again in 9 weeks and see if they are any drier :)
318isPMK
Post Mon Jan 28, 2013 11:51 pm
snakebrain
Post Tue Jan 29, 2013 12:20 am
318isPMK
Post Tue Jan 29, 2013 12:24 am
lol its okay its being rectified :)
Post Tue Jan 29, 2013 12:29 am
At least by deleting the 'jacking points' the floors won't go rusty............
PS has anybody taken a screwdriver to the rear inner arches yet ? :eek:
Post Tue Jan 29, 2013 12:43 am
Jesus that's grim,
sadly experience tells me that once it's got severe rot in those lower area's there's little hope of fixing the rest without throwing a LOT of money at it :(
cut your losses and frag it... after all it's just a 318
seriously, it just isn't economically viable :cry:
318isPMK
Post Tue Jan 29, 2013 1:10 am
Yes. Pete.
Ive had a quote of a couple of hundred to sort it so I dont see the big deal.
Why is everyone so keen to rip cars to bits.
Whats is worth in bits?
Green
Post Tue Jan 29, 2013 2:14 am
318isPMK wrote: Whats is worth in bits?
Not as much as driving it on the road in the summer sun 8)
318isPMK
Post Tue Jan 29, 2013 8:20 am
Exactly! Even in the Glasgow summer hail
Andyboy
Alpina Colada
Post Tue Jan 29, 2013 6:15 pm
318isPMK wrote: Image
Aah, a Diddler special. Nice!
I wouldn't spent 200 pence on this thing. Just tidy it up enough for an MOT and flog the POS when it's got 2 months left.
