Headlamp washer system reservoir question
jimf
Post Tue Jan 22, 2013 2:53 pm
Hi folks.
I took the washer bottle out my car today to investigate a leak and to clean it up a bit.
I'm just wondering, is the smaller bottle specifically for the headlights? I have deleted my headlight washers and am just trying to figure out how the system works so I can either disable the headlight part of the reservoir or simply fit a standard bottle.
Do the standard non headlight bottle still have two motor pumps?
Topblag
Post Tue Jan 22, 2013 2:55 pm
jimf wrote:Hi folks.
Standard is one pump, twin bottle is two pumps.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
FinalD
Standard is a single bottle and single pump. Headlight systems have two bottles and a pump on each. The bottles are joined by a plastic bar but are separate containers (one doesn't fill the other if empty).
jimf
Post Tue Jan 22, 2013 2:59 pm
Ok I seem to have one pump on small reservoir and two on the big one. If I were to fit a standard bottle would it matter which pump I used?
Gert_8
Post Tue Jan 22, 2013 3:01 pm
jimf wrote:Ok I seem to have one pump on small reservoir and two on the big one. If I were to fit a standard bottle would it matter which pump I used?
I'd like to see a pic of that, please?! 3 pumps is very unusual. If you adapt to one bottle, you will only require one pump.
Post Tue Jan 22, 2013 3:08 pm
all headlight wash wiper bottles have x3 pumps,one is hidden close to the inner wing and feeds the head lights,the one you can see on the large bottle feeds the windscreen on normal wash and the pump on the smaller bottle is the intense wash and feeds the screen when you push the 'S' inward on your washer stalk .
Gert_8
Post Tue Jan 22, 2013 3:10 pm
magpie wrote:all headlight wash wiper bottles have x3 pumps,one is hidden close to the inner wing and feeds the head lights,the one you can see on the large bottle feeds the windscreen on normal wash and the pump on the smaller bottle is the intense wash and feeds the screen when you push the 'S' inward on your washer stalk .
Have you got a pic, please, Mick? - inner arch hidden one.
Post Tue Jan 22, 2013 3:20 pm
look at the recess on the large bottle,the pump hides here
Gert_8
Post Tue Jan 22, 2013 3:21 pm
Thanks! I'll take a look see tonight.
FinalD
Post Tue Jan 22, 2013 3:25 pm
I'm fairly sure my double bottle only had two pumps...I'll also check tonight. :D
Topblag
Post Tue Jan 22, 2013 3:36 pm
Clearly the setup on my car is wrong ! Every day is a school day.
Post Tue Jan 22, 2013 7:00 pm
This! No E30 had two pumps.
Gert_8
Post Tue Jan 22, 2013 7:30 pm
Checked the bottles, and indeed there it was, little bugger tucked away just as Mick advised!! :D
FinalD
Post Tue Jan 22, 2013 8:23 pm
Checked mine just now, and yup. Three, totally forgot about the third if I'm honest. :)
