are they different ,and if so what's the difference ?
i think the 325i one is shorter but will the 320i one not adjust/shorten to suit a medium case diff from a small case one ?
tia Mick.
320i v's 325i propshafts
+ a yard full of scrap turds
johnl320
rear half of the prop will shorten for different diff but front half are different lengths beacause the 325 gearbox is longer than the 320 one
Grrrmachine
- E30 Zone Wiki / Team Member
It's not the diff size that's the issue, it's the gearbox. 320i's use the Getrag 240 gearbox, which is significantly shorter than the 325i's Getrag 260, and you can't adjust the prop enough to compensate for that. If you're using a 240 box and a large case diff, you can use a 320i prop.
It's all in the Wiki...
http://www.e30zone.net/e30zonewiki/inde ... #Propshaft
- **BANNED**
All props have the same rear section,it's the front that is different.
I have a 320 prop on the touring,mated to a Getrang 240 and an M50 at one end and a 3:64 medium case diff at the other.
Youth is wasted on the young.
ok cheers,clear as mud lol.
- **BANNED**
If your shaft is reluctant to shorten,try a bigger hammer....magpie wrote:ok cheers,clear as mud lol.
Andyboy
- Alpina Colada
daimlerman wrote:If your shaft is reluctant to shorten, stop looking at pornmagpie wrote:ok cheers,clear as mud lol.
- **BANNED**
Bloody newly weds!Andyboy wrote:daimlerman wrote:If your shaft is reluctant to shorten, stop looking at pornmagpie wrote:ok cheers,clear as mud lol.
