Illuiminated Rear Heated Window Switch
kam-325i
Post Fri Dec 16, 2005 7:40 pm
I want to do the mod as in the tech articles, where do i get the "Modified" switch from ?
buster
Post Fri Dec 16, 2005 8:32 pm
Ask Ian haynes nicely and he may do you one,he's the man for these.
kam-325i
Post Fri Dec 16, 2005 8:38 pm
buster wrote:Ask Ian haynes nicely and he may do you one,he's the man for these.
aahh. so you have to mod the switch aswell........
johno
Post Fri Dec 16, 2005 8:43 pm
yes mate ou need demister switch and a hazard switch to mod
kam-325i
Post Fri Dec 16, 2005 8:45 pm
johno wrote:yes mate ou need demister switch and a hazard switch to mod
Take the bits out of the donor hazard and put into the demister ?
ian332isport
Post Fri Dec 16, 2005 8:52 pm
Yeah, that's basically what needs doing. I also change the reisistor value to give the correct brightness.
Aparently you can just swap the switch cover from a heated rear window switch into a hazard switch and it works. Never tried it like this though.
Ian.
kam-325i
Post Sat Dec 17, 2005 6:26 pm
Right, Ive got the two switchs in front of me, both in peices, which bits from the hazard do i put into the rear heater ?
stevetigger
Post Sat Dec 17, 2005 6:30 pm
kam-325i wrote:Right, Ive got the two switchs in front of me, both in peices, which bits from the hazard do i put into the rear heater ?
http://www.e30zone.co.uk/modules.php?na ... witch1.htm
That might help!!
kam-325i
Post Sat Dec 17, 2005 6:37 pm
Thats not what i need, The Actual rear heated Screen Switch internals need bits adding to it from the inside of the hazard switch. But i dont know which bits.....
smithy318i
Post Sat Dec 17, 2005 6:52 pm
yes you can do that
kam-325i
Post Sat Dec 17, 2005 7:12 pm
yes you can do that
WooHoo, Right then, just got to rebiuld the damm switches now !!! :lol:
oze30
Post Sat Dec 17, 2005 7:17 pm
Then what are the rest of the wires out the back of the plug (window) for? If I remember, the hazard has less wires. Eitehr way.. I'm going to do this mod right now! ;)
Cheers guys!
kam-325i
Post Sat Dec 17, 2005 7:46 pm
oze30 wrote:Then what are the rest of the wires out the back of the plug (window) for? If I remember, the hazard has less wires. Eitehr way.. I'm going to do this mod right now! ;)
Cheers guys!
The Hazard Switch has 8 Connetors on the back, the heated screen switch has 4.
smithy318i
Post Sat Dec 17, 2005 7:50 pm
Cheers guys!
yes but the 4 terminals on the heater switch is the same layout as the 4 on the hazard switch.
The others just are not used
FESI
Post Sat Dec 17, 2005 10:56 pm
So if the swap has made is the extra wire needed from the tech article or it will work without it
oze30
Post Sun Dec 18, 2005 7:02 pm
Hmm.. slight problem. My heated switch plug has 3 wires/pins.. where did my 4th one go???
kam-325i
Post Mon Dec 19, 2005 9:13 pm
FESI wrote:So if the swap has made is the extra wire needed from the tech article or it will work without it
Yes, as this is the "Dimmed" supply for the bulb.
johnono
Post Mon Dec 19, 2005 11:24 pm
so the extra wiring is needed, u cant just swap the cover of a demister on a hazard switch and violá.
or not..
stevetigger
Post Mon Dec 19, 2005 11:25 pm
johnono wrote:so the extra wiring is needed, u cant just swap the cover of a demister on a hazard switch and violá.
or not..
Good idea!
johnono
Post Mon Dec 19, 2005 11:28 pm
or not..
Good idea!
what is? i was askin a question :lol:
Demlotcrew
Post Mon Dec 19, 2005 11:30 pm
No you cant.
Andrew
johnono
Post Mon Dec 19, 2005 11:32 pm
the covers arenԚ´t actually the same or the componetry inside is different?
kam-325i
Post Tue Dec 20, 2005 12:08 am
johnono wrote:the covers arenԚ´t actually the same or the componetry inside is different?
Right, here goes.
Switch covers are swappable
The extra wire is needed to supply the voltage to the switch for the dimmed light.
johnono
Post Tue Dec 20, 2005 12:16 am
good man for checkin that out ;)
stevetigger
Post Tue Dec 20, 2005 12:37 am
Right, here goes.
You will have to come round my house Keith and show me how its done!
What parts do I need to get?
kam-325i
Post Tue Dec 20, 2005 12:47 am
Atleast a hazard switch to butcher, but a spare heated screen one aswell, just in case, also a spare spade connector for the heated screen.
stevetigger
Post Tue Dec 20, 2005 2:03 am
kam-325i wrote:Atleast a hazard switch to butcher, but a spare heated screen one aswell, just in case, also a spare spade connector for the heated screen.
You bring the spade, I will get hold of the switch's......I can see a trip to furbers! Tomorrow
Jordan
Post Tue Dec 20, 2005 2:19 am
Someone please explain this modification to me?
My defroster switch already lights up, and dims with the dash lights.
So does the one in my girlfriends 89 325i...
stevetigger
Post Tue Dec 20, 2005 2:52 am
Jordan wrote:Someone please explain this modification to me?
Well here, the rear de-mister switch does not light up!
kam-325i
Post Tue Dec 20, 2005 9:27 am
As standard, the rear heated screen switch is not illumminated when you switch on the lights, only when the switch is in the "On" position.
Not sure if this happens on US models.
kam-325i
Post Tue Dec 20, 2005 9:28 am
stevetigger wrote:You will have to come round my house Keith and show me how its done!
It would have to be a weekend......
stevetigger
Post Tue Dec 20, 2005 8:46 pm
Anytime mate, The cars in bed anyways.....So I need two switches?
kam-325i
Post Tue Dec 20, 2005 8:51 pm
Just a spare really, just in case, sods law and all that ! :) winkeye
stevetigger
Post Tue Dec 20, 2005 9:06 pm
ok, Ill get a switch and then we can do this little job on my car!
I take it you mean a spare hazard switch?
kam-325i
Post Tue Dec 20, 2005 9:11 pm
Nah, a spare rear screen switch.
Youll need atleast one hazard switch to butcher, and a spare rear screen in case of.......something !!
